WiFi Key Length
vk5rr
WiFi Key Length
Post by vk5rr » Sun Feb 19, 2023 12:40 pm
Hello
I have tried to enter our WiFi key into the Portsdown only to find that it will not accept the full length, is there a reason for the artificial character length of the key that I can enter
Ray VK5RR
Re: WiFi Key Length
Post by g0mjw » Sun Feb 19, 2023 7:05 pm
It is probably limited to make it usable on a touch screen. I think the maximum is 63 characters but recommended 32. Even so, there is no point in having such a long pass phrase. I would think 16 sufficient to be too hard to guess. For now you will need to set it manually in the usual way, as you would when building a card.
vk5rr
Re: WiFi Key Length
Post by vk5rr » Mon Feb 20, 2023 6:47 am
Hello Mike
Thanks for the info but we have too many devices on the network to go and change to a 16 character password always run long WiFi passwords
Have SSH'd into the pi and configured it thru the raspi-config program but would have been easier thru the Portsdown
Regards
Ray - VK5RR
gm1mfn
Re: WiFi Key Length
Post by gm1mfn » Mon Feb 20, 2023 11:02 am
Most routers support multiple accounts, so you could create a separate account on your router for the Portsdown and give it a shorter password.
Re: WiFi Key Length
Post by G8GKQ » Mon Feb 20, 2023 2:31 pm
Thanks for pointing this out Ray
The overriding limitation is the touchscreen interface, specifically the keyboard function that I wrote which is used by many of the Portsdown user input screens. The string length input limit for that function is currently 23 characters and it would need a lot of testing before I could be confident that a change would not have adverse effects elsewhere.
However, the 15 character limit for a WiFi SSID was unnecessary, so I will increase that to 23 in the next Portsdown 4 update.
vk5rr
Re: WiFi Key Length
Post by vk5rr » Sun Feb 26, 2023 4:01 am
Hello Dave
No problems, it is just that we have long passphase on all access to our routers for security reasons, and we do get reports of the numerous attacks daily on the system/s we have running
The SSID is no issue, only the complex passphase protecting the network, thanks again for assisting one and all
Regards
Ray - VK5RR
