2.4 PA in ebay
Re: 2.4 PA in ebay
Hi Esko,
I use the electric hob in the kitchen (while the XYL is out) to warm the pallet to 180-200C and then carefully heat the part to be removed until the solder melts with a gentle heat gun as it is easy to loosen and move nearby components. The pallets can absorb a lot of heat so I don't think a heatgun on its own would be enough. An infra red thermometer is a definite help.
73 Dave
73 Dave
Re: 2.4 PA in ebay
Mike,
Yes, they added the components that do the x 10 and switched in or out.
- 20230214_183422.jpg (1.68 MiB) Viewed 6829 times
Re: 2.4 PA in ebay
Interesting. I will have a look out for one. They are a bit pricey new.
Re: 2.4 PA in ebay
Mike,
Mine must be 20yrs plus old now, was purchased when first started with fm tv, when GB3PV went on air (late 90's) its only a mile or so from my location.
Re: 2.4 PA in ebay
Hello
One question.
What kind of pre amplifier is needed ?
Br. Esko Petäjä
One question.
Br. Esko Petäjä
Re: 2.4 PA in ebay
Hello Dave
I have one portable unit and also old reflow Owen controller. I need to build heather .
Sometimes you need to build your tools before actual job.
One question, my unit is still in transfer.
I need to cut .aluminum plate.
I did not found unit dimension anywhere ?
Br. Eskop
Br. Eskop
Re: 2.4 PA in ebay
Or use the iron from the missis and clean it before using it on clothes again...
Benno
Benno
- G1LPS Terry
Re: 2.4 PA in ebay
Hi Brian (hsf)
Any chance of some pictures of both sides of the circuit board in the CN-801 s meter Id like to look at adding a x 10 to mine.
looks like the black pot is extra for a start
Terry g1lps
Terry g1lps
Re: 2.4 PA in ebay
Hi Terry,
Will need to have a look inside again to do that, from what I remember where the extra black pot is (50k) and open one end, it looks like the mod was taking that part on the pcb out (link or fixed resistor) and install the pot in its place, with the switch just shorting out the pot, and having an rf source to set the x 10.
