WinterHill Receive Commander HELP
I am using WinterHill Receive Commander to monitor my input signal to QO100 on 2409.750.
All 4 windows work OK on QO100
If I try and send the input parameters 333ks 2409.750 BOT AE SKT only window 1 or 2 will decode.
Windows 3 and 4 "search" SR333 2409.750Mhz B but never decode.
Martin
G8KOE
Martin
G8KOE
- Screenshot 2023-01-23 104931.jpg (418.08 KiB) Viewed 7022 times
Re: WinterHill Receive Commander HELP
I have just been transmitting through QO100.
Window 1 and 2 are monitoring input (2409.750Mhz)
Window 3 and 4 are monitoring output of QO100
Martin
G8KOE
Martin
G8KOE
1 and 2 input
3 and 4 output
Martin
G8KOE
1 and 2 input
3 and 4 output
Martin
G8KOE
- input and output.jpg (566.96 KiB) Viewed 7014 times
What is your WH antenna set up?
All the VLC and info screen pictures are showing only the BOT sockets in use. For QO-100, normally the 2 TOP sockets would be fed from a splitter and the 2 BOT sockets would be used for uplink monitoring and terrestrial, or vice-versa.
The local sockets may be able to pick up your uplink without anything connected, but a short piece of wire is probably worthwhile.
Hi Brian,
Top two are connected to a splitter for QO10
the RH bottom socket is connected to a small local pickup AE.
With same settings from Commander transferred to all 4 windows could only get local on 1 and 2.
I didn't expect to end up with 1 and 2 local 3 and 4 on QO100 after transferring the settings from Commander.
I expect it's me not understanding how it works.
Martin
G8KOE
Martin
G8KOE
- Commander.jpg (161.52 KiB) Viewed 6982 times
- 20230123_142453s.jpg (85.36 KiB) Viewed 6982 times
You'll also need a pickup antenna on the BOT socket of the other NIM (NIM_B) if you want the capability to see your uplink on any of the 4 receivers.
For QO-100, I would suggest having a pickup only on NIM_B (left, looking into the sockets) and configuring only RX4 for uplink in whpcviewer.
That way, when you want to view your uplink for a while, you can configure QuickTune to use only 3 receivers and use RX4 for your uplink.
Hi Brian,
Thanks for your reply and help.
Will do what you suggested.
Always more for me to learn!
73's
Martin
G8KOE
73's
Martin
G8KOE
You are using H265, not supported on the two bottom receivers.
That is the case when viewing on a monitor connected to the WH RPi, but there is no restriction for H.265 when using the WH as a hub and viewing on a PC.
