WH is not starting after installation
DG8KD
Re: WH is not starting after installation
Post by DG8KD » Tue Dec 06, 2022 12:15 pm
g0mjw wrote:
Tue Dec 06, 2022 9:16 am
DG8KD wrote:
Mon Dec 05, 2022 6:36 pm
Were you using the attached keyboard rather than an SSH login? You need to be using the keyboard to start the launch files.
[b]No command line, no input possible,  so only remote keyboard via ssh[/b]
Surely this is the problem - using an attached screen but a remote keyboard?
As the display is stucking at local.service, no chance to use the keyboard connected via USB to the PI.
No reaction on key presses,,,
Post by G4EWJ » Tue Dec 06, 2022 1:45 pm
With htop, can you see the rc-local.service process running? If so, try killing it.
DG8KD
Post by DG8KD » Thu Dec 08, 2022 12:29 pm
Is there any chance to get rid of the SD card and host and boot the system via the USB ports? A small SDD/ USB stick is cheap and maybe more suitable as a SD.
My PI works perfect with Buster and Desktop, but after installing WH it stops booting....
Post by G4EWJ » Thu Dec 08, 2022 1:37 pm
It's difficult to know if USB boot would work, until we know what the problem is. This is the first time I've heard of it happening.
Let me work out a minimal, manual installation plan and you can reboot after every stage to see what stops it booting.
DG8KD
Post by DG8KD » Thu Dec 08, 2022 1:58 pm
Hi Brian,
I will try to migrate to USB tomorrow, should not be really rocket sciences.
If it fails the same way, no clue.
What makes me worries: Also the modified WH from Tom, ZR6TG fails at the same point. https://www.zr6tg.co.za/winterhill-datv ... er-client/
Rainer
Post by G4EWJ » Thu Dec 08, 2022 4:07 pm
I wonder if it could be a memory problem on the RPi? As you install more things, it reaches a bad part of ram.
Try putting these two lines in /boot/config.txt before installing WH and see if it reboots.
Have a look for an RPi ram test program.
gpu_mem=128
force_turbo=1
Post by G4EWJ » Thu Dec 08, 2022 4:20 pm
Also, after a hangup, try removing the lines from/etc/rc.local that insert the WH driver into the kernel and reboot.
cd /home/pi/winterhill/whsource-3v20/whdriver-3v20
sudo insmod whdriver-3v20.ko
Post by G4EWJ » Thu Dec 08, 2022 4:44 pm
Try this after trying the above.
If you have a hanging WH version, first copy the WH kernel module to a PC, to use further down
Look for whdriver-3v20.ko in /home/pi/winterhill/whsource-3v20/whdriver-3v20
Make a new SD card, do the usual on-screen configuration and reboot at each blank line
gpu_mem=128
force_turbo=1
sudo apt-get -y install xdotool
sudo apt-get -y install xterm
sudo apt-get -y install raspberrypi-kernel-headers
sudo mv /etc/xdg/lxsession/LXDE-pi/sshpwd.sh /etc/xdg/lxsession/LXDE-pi/sshpwd.sh.old
cd /home/pi/.config/lxpanel/LXDE-pi/panels
sed -i "/^ edge=top/c\ edge=bottom" panel
sudo sed -i "/^#dtparam=spi=on/c\dtparam=spi=off\ndtoverlay=spi5-1cs" /boot/config.txt
sudo sed -i "/^dtoverlay=vc4-fkms-v3d/c\#dtoverlay=vc4-fkms-v3d" /boot/config.txt
sudo sed -i "/^#hdmi_force_hotplug=1/c\hdmi_force_hotplug=1" /boot/config.txt
If you have saved whdriver-3v20.ko, put it back on the RPi (anywhere) and type:
reboot
DG8KD
Post by DG8KD » Sat Dec 10, 2022 3:29 pm
Performed a whole bunch of memtests, none of them failed.
That´s good news, so PI itself seems to be OK.
gpu_mem=128
force_turbo=1
DG8KD
Post by DG8KD » Mon Dec 12, 2022 1:31 pm
Update:
I removed the PI from the WH PCB and did the programming without any connection to the PCB.
And: It works....After the installation it reboots and starts in local mode.
So it seems something on the PCB is causing my problems. As the values of the 3 voltages are not shown any deviation to the expected values (1.097 V / 3.31 V and 5.15 V)
After the reinsertion of the PI onto the board and booting up the WH started in local mode. Weird !!! Same PSU, same micro SDHC card, same cables, same Buster build, same Windows PC,
THANKS for your support!!
Will do a set of reboots to see if it comes up again.
