29MHz trans Atlantic DX...
I've got my TX rigged up now.
I can see myself on a kiwisdr nr Washington: http://kiwisdr.k3fef.com:8073/
If someone had a good antenna and rx maybe it would work, but would have to catch it when the fading is not as brutal!!
DRM mode may be the only way.
This is 66Ks DVB-S2, 29.250MHz.
- sdr rx_fading.jpg (815.43 KiB) Viewed 6556 times
- sdr rx.jpg (566.43 KiB) Viewed 6556 times
Found your callsign and just heard what sounded like distorted sideband on your frequency. Possibly another operator.
Steve
Steve
Yeah, there's a few signals come up since i posted!
Signal is very QSB, that's 100W into 3el yagi here.
The Rx says it's a loop: https://sites.google.com/view/vk1hw/ant ... ermes-loop
Looking good Rob.....
I have so much HF QRM at home that my spectrum looks like that already, with or without any DVB, but am watching on my SDR.
Been playing with this little amp https://sites.google.com/site/rfpowerto ... ower-tools which I built a couple of years ago.
From Mikes transverter O/P into a 20db eBay amp gave 0.1W. Then into this amp gave me 6 watts. More was seen but tweaking the bias greatly improved the 'byproducts' until I think I have popped the device (really need a current limited 50V PSU.....). No smoke but its stopped amplifying......
I have several spare PCBs for this amp if anyone would like one....it would probably be good for a beacon amp running relatively QRP if the band obliges 5W will probably work.....or I suppose tunr down a MRF300 would achieve the same.....tx output filter also required....
I am just looking but I don't see any signals. The SDR queue is full.
I can see that carrier, I tried sending a CW carrier but it doesn't appear, so no path for me at the moment.
Sounds good Gareth,
You maybe able to hear some backscatter from me on ssb maybe but DVB unlikely as it will be too weak.
The DATV source:
Pluto -> ham-it-up converter -> SPF5189 -> RD06 -> BLF188 and LPF.
Image below, excuse the tip of bench, work in progress!!!!!!
The DATV source:
- 20221106_154527.jpg (472.21 KiB) Viewed 6539 times
Stronger than it was now, but major frequency selective fading.
good signal on my local kiwisdr only about 2 miles away.
http://planet3.dyndns.org:8073/
- sdr rx_stronger_2.jpg (288.08 KiB) Viewed 6536 times
Possibilities with this sort of strength, more stable too.... interesting.
- spectrum.jpg (493.84 KiB) Viewed 6503 times
- sdr rx_stronger_3.jpg (568.41 KiB) Viewed 6503 times
Some more images of Today's tests, Tx is now off as conditions have faded in darkness.
The strongest peak came up to 20dB/noise on the websdr.
I did a comparison with 66Ks DVB-S2 vs 333Ks DVB-T.
- strongest peak.jpg (153.58 KiB) Viewed 6489 times
- 66Ks vs 333Ks.jpg (160.46 KiB) Viewed 6489 times
