Lime SDR vs Lime SDRmini
G6OTP
Post by G6OTP » Wed Oct 26, 2022 1:06 pm
I have the opportunity to buy a Lime SDR. (The big brother.) From what I have read, It seems as if it will work with the Portsdown in place of the mini but I would really like to be sure. I would appeciate you help.
Mike G6OTP
Re: Lime SDR vs Lime SDRmini
Post by radiogareth » Wed Oct 26, 2022 1:20 pm
Mine worked fine until part of its PSU circuit 'expired'.
Post by G8GKQ » Wed Oct 26, 2022 1:37 pm
Hi Mike
Yes, the LimeSDR USB does work with the Portsdown.
I have tried to make all the facilities that normally work with a LimeSDR Mini compatible with the Lime USB, but there are things like LimeDVB mode that won't work because the (3rd party) firmware does not exist.
Let me know if you run into any specific issues.
Post by g0mjw » Wed Oct 26, 2022 2:17 pm
The LimeNetMicro also works, should you come across one. Maybe we need a truth table in the Wiki.
G6OTP
Post by G6OTP » Thu Oct 27, 2022 8:43 am
Very many thanks for your replies and I shall go ahead with the purchase. I am looking forward to comparing it with the Pluto.
Mike G6OTP
Post by g0mjw » Thu Oct 27, 2022 9:01 am
Mike G6OTP
Hi Mike,
They get very hot so I suggest a small fan blowing air over the PCB. There was an affordable case available, I am not sure it still is.
This is basically two PCBs front and back and a cheap metal clam shell enclosure with a hole for a fan.
