September 10/11th Activity
I'm planning to be out portable in IO94 with 2m/70cm/23cm for this coming activity weekend.
Weather is looking reasonable.
I can do either day, any preferences?
Re: September 10/11th Activity
Domestically booked on Saturday, Sunday morning for me Rob, I can set up for either 2 (ERP limited) or 70cms lots of RF. Sunday afternoon I'm out on 24Ghz....
Away on Saturday and doing the 24/47/76 NB contest on Sunday so not going to be out this time.
Sunday it is then.
I'll be at IO94MJ from ~10am.
Zello (ATV South, ATV Northeast) / Dxspot / 144.750 Talkback.
OK, unless there is a lift on I'll set up for 70cms and get the mast up. 350 degrees from me to you. Fingers crossed this time.....
Two contacts today:
Nick G4NKV on 2m/23cm 2-way, 70cm 1-way - short but very obstructed path.
Clive G4FVP on 2m and 23cm 2-way - also short obstructed path.
Failed with Gareth G4XAT on 70cm again... we will work one day!, and Steve M0SKM on 23cm.
Saw weak signals on band viewer but not stable enough to geta decode.
