Ryde + pi 2gb, MiniTiouner
g6hfs
Post by g6hfs » Sun Jul 10, 2022 3:47 pm
When there is no signal and the menu is selected should the screen go blank, will some time flash back but only comes back on when the menu is deselected
Comments?
https://youtu.be/__xb10nzHss
Brian(G6HFS)
G4IMO-TV
Re: Ryde + pi 2gb, MiniTiouner
Post by G4IMO-TV » Mon Jul 11, 2022 9:45 am
No Brian that's not good.
The Ryde screen should just sit there showing a red screen saying Not Locked.
Nick
G4IMO
Post by G8GKQ » Mon Jul 11, 2022 9:50 am
Hi Brian
I need more information before I can investigate this.
  • Was it a new build?
  • What software version?
  • Does the same MiniTiouner work with another Ryde, Portsdown or a PC?
g6hfs
Post by g6hfs » Mon Jul 11, 2022 3:11 pm
Yes, current build, latest software version on and have tried it on 2 pi 4b a 2gb and 4gb separate builds, the MiniTiouner is ok on my pc and laptop
Brian (G6HFS)
g6hfs
Post by g6hfs » Mon Jul 11, 2022 3:34 pm
Footnote:
It does the same with keyboard/mouse unplugged, and MiniTiouner in any free usb port v2 or v3 black/blue.
Post by G8GKQ » Mon Jul 11, 2022 3:53 pm
Alarm Bells are ringing!
Why would you have a keyboard or mouse connected to a Ryde? If you use the recommended build, neither will do anything sensible.
What Raspberry Pi software are you using?
g6hfs
Post by g6hfs » Mon Jul 11, 2022 4:13 pm
Dave,
I was just looking to see if a keyboard or mouse made any difference but no, I do use ssh to pi 4b
Picture with details attached.
g6hfs
Post by g6hfs » Mon Jul 11, 2022 4:16 pm
Dave,
Sorry forgot to add soft ware on mini sd from batc shop, now updated.
Post by G8GKQ » Mon Jul 11, 2022 9:01 pm
Hi Brian
I have just down a new build and not been able to reproduce this. Please provide some diagnostics by going into the menu, Select Ryde Utility and then select display test. You should get something like this:
Your System Response:
pygame 1.9.4.post1
[2]
(1280, 720)
60.0Hz
(1, 1)
Layer successfully created
Surface successfully created
Performance test starting
Performance test complete
54.67fps
91.11%
Surface successfully deleted
Layer successfully deleted
Press any key to return to the menu
Note that you can copy code from a PuTTY or KiTTY window by highlighting it and then pasting it into the Forum.
g6hfs
Post by g6hfs » Mon Jul 11, 2022 9:19 pm
pygame 1.9.4.post1
[7]
(1920, 1200)
60.0Hz
(1, 1)
21.34fps
35.56%
Tests under 75% max frame rate, performance may be impacted
This is my results
