DATV-Easy V2.00 >> Download V1.25
Pa3fbx
Re: New soft DATV-Easy V1.0 >> V1.24
Post by Pa3fbx » Sun Apr 10, 2022 8:51 am
I got finally some extra time to invest in testing this version.
Yes it works with any F5OEO version (the last few need to be in rtmp mode)
It also work with the 2020 versions as they all could work with RTMP without any changes.
It's also works with IP over network.
The only bug yet found is when any pluto is connected to USB it will Always use that Pluto first.
When using the networked pluto's you can set the ip number and it will used that pluto (i have 3 on network.. sorry :oops: )
So big improvement where as i can use now any firmware and any connection.
Bug report. when 1 pluto on USB than no other pluto will be detected while starting.
When transport is started you can switch and connect all pluto's to any port but when you stop the transport the next tx wil be on usb pluto.
Thanks dominique.
Benno, PA3FBX
F1EJP
Post by F1EJP » Sun Apr 10, 2022 11:58 am
Hello Benno,
Thank you for this very detailed and professional points.
I may have a solution to test for Pluto recognition.  I send you soon a file to test.
There are some cuts at startup it comes from ffmpeg which takes a few seconds to stabilize, I will try to optimize.
Thank you for this very constructive feedback which contributes to the development of our hobby.
73 Dominique F1EJP
F1EJP
Re: New soft DATV-Easy V1.0 >> V1.25
Post by F1EJP » Sat Apr 23, 2022 10:16 am
Hello everyone
I am waiting to receive an Adalm Pluto from Analog Devices to optimize the tests on Ethernet.
As soon as possible I will make available for all on vivadatv.org a first version of DATV-Easy v1.25
In 1.25 optimisation buffer ffmpeg and possibility to edit frequency (Easy) :D
ATTENTION if your pc is not powerful enough it produces drops: :oops:
minimum prerequisite:
- processor I5 and preferably I7
- graphic card with GPU or processor Intel with GPU
- USB 3
73 Dominique F1EJP
F1EJP
DATV-Easy V1.0 >> Download V1.25
Post by F1EJP » Mon May 16, 2022 8:00 pm
After making you wait a bit, here is a first version of DATV-Easy V1.25
Thanks to all Beta testers!
I remind you that this is an amateur development based on GNU RADIO and FFMPEG and is therefore experimental!
Please read the manual before any questions!
73 and have fun :D
Dominique F1EJP
http://www.vivadatv.org//viewtopic.php?f=84&t=901
G7JTT
Re: DATV-Easy V1.0 >> Download V1.25
Post by G7JTT » Tue May 17, 2022 7:35 am
Excellent work Dominique, no issues with the install of either your software or the lime. Working well on a i5 laptop with a RTX 2060 using a Lime mini.
Cheers John G7JTT
G7JTT
Post by G7JTT » Tue May 17, 2022 7:50 am
This is a screen shot of Task Manager showing still room to spare with resources
Post by radiogareth » Tue May 17, 2022 8:09 am
Thanks very much for this release _ I have been using your FSC2.8 without any problems. This is a huge leap :-)
Would it be possible to expand the TX range up to 6GHz for the Pluto? That would then allow DATV on 5.7Ghz :-)
Many thanks again for all your work :-)
Post by g0mjw » Tue May 17, 2022 8:24 am
Great work. It installed OK on this nvidia laptop. I will test with various laptops and see.
Not wishing to create issues but is it possible to tweak some of the more advanced ffmpeg parameters? E.g. on another screen. It can't cope as well with full HD at 333ks as my script but I am not sure why. Buffers maybe or perhaps the encoder settings. It does work but keeps exceeding the TS rate target.
Also my default FPS is 15, not 30. That's not in the drop down menu. It would ne nice if it were.
Basil
Post by Basil » Wed May 18, 2022 10:05 pm
Firstly many thanks for your work on this application. I have been using the older Free Stream Coder V 2.80 with no issues. I downloaded the current version of DATV-Easy (V1.25) and it installed seemingly without errors, and when I launch it the application opens and can be modified, but when I press "Start" I get this:
"The program can't start because Api-ms-win-core-path-l1-1-0.dll is missing from your computer".
I installed the claimed missing .dll manually in C:/Windows/sysWOW64 but the error is still present.
OS is Windows 7 64 bit Pro. I am trying to run it on the same PC as is currently running Free Stream Coder fine. May I trouble you for any ideas how I might go about fixing this please, and thanks again for your work.
Best regards,
F1EJP
Post by F1EJP » Thu May 19, 2022 1:12 pm
Hello Basil,
It is a problem Microsoft
Maybe install or reinstall Microsoft Visual C++ Redistributable Package 64bits and or 32bits
73 Dominique
