Activity Weekend 9/10 April 2022
Hi all.
I hope to be out portable this coming weekend with 70cm and 23cm from IO94LI most likely.
Saturday weather is slightly better but not much in it, i can do either day.
Anyobe else coming on?
Re: Activity Weekend 9/10 April 2022
Hi Rob, I'm certainly planning on being active/out with my new amp on 70cms (150W+ DVBS-2), either from home or 'somewhere in the SE (TBC)' on Saturday, then again from Burton Dassett hills (approx IO92GD99IO) on Sunday.
70cms, 23cms (not got much power or gain on 23 ATM) and 3.4GHz with 40W+.
Hi All
My current plans are to be out portable, on a hill somewhere within an hour of Salisbury, with 70 cms and 23 cms on Saturday from 1 pm onwards.
More details to follow
Looking good for the weekend with only a little chance of rain and a high pressure moving in over the country....
Excellent.
Saturday it is then.
I won't have qro on 70cm this time so may not be as successful but lets hope conditions are reasonable.
I will be on from home on Sunday only on 70cm (antenna fixed at 090 degrees) & 9cm & 6cm & 3cm DATV plus 6cm FMTV.
437Mhz 3402.5MHz 5762.5MHz DATV and 5665MHz FMTV
I have a good takeoff from North through east to around 110 degrees
G4FRE
G4FRE
I hope to have a small 70cm station operating from Nunburnholme Wold in East Yorkshire, IO93PV79IK, on Saturday afternoon.
Clive
G3GJA
Clive
G3GJA
Just back from a week in Devon - no radio apart from rxing NQ on Dartmoor at 50km with a 15dB MER. Equipment problems meant no txr
I'll try and get out tomorrow with 70cms from Midday probably at IO91JH (Hannington) with good take-off to the North.
I can confirm that I will be at Lane End, near Winchester (IO91JA) with 146, 437 and 1255 MHz from 1pm this afternoon. Talkback 144.75 and Zello ATV South.
Activity in the south via Aircraft scatter happening now.
Talkback is happening on Zello ATV South.
