Customising the Ryde information display
Re: Customising the Ryde information display
So I am right in thinking :-
timers:
USERTRIGGER: 10
PROGRAMTRIGGER: 10
represent 10 second time outs for the MER/dB Report and if so could we make these 60 on our repeater?
Paul G6MNJ
timers:
USERTRIGGER: 10
PROGRAMTRIGGER: 10
Paul G6MNJ
Yes, USERTRIGGER is the timeout for when you press select on the remote, PROGRAMTRIGGER is the timeout when it activates itself, both in seconds.
Tim MW0RUD
Tim MW0RUD
I read the earlier comments regarding editors - I presume I can edit this with nano can I or that too dangerous too?
Paul
Paul
Paul
nano would be my choice from the command line. I use it a lot with Ryde and Portsdown.
I would use vi (or vim) but expect I am in a bit of a minority there.
You are Mike, i just can't get away with vim.
Hello @all,
I think this has already been mentioned somewhere, but I can't find it again.
Is it now possible to use both inputs of the SAT tuner in scan mode?
E.g. upper for 23cm, lower entrance for 13cm?
73 Thomas
DL5BCA
DL5BCA
No I don't think so.
But you can send remote tune commands with specific scan parameters either on the Ryde itself or over LAN.
See github example:
https://github.com/eclispe/rydeplayer/b ... orktest.py
See github example:
You could re-write the code to do that, but not at the same time. This is a one channel at a time receiver. If you want to do this it might be better to use the WinterHill board.
Thank you for the answer.
of course I was thinking of scanning sequentially, similar to scanning to different frequencies on the QO100.
First Ryde scans the SR 1000kB and 333kB on the upper input at 23cm, then the SR 1000kB and 333kB on the lower input at 13cm.
73 Thomas
DL5BCA
DL5BCA
