Customising the Ryde information display
G6MNJ
Re: Customising the Ryde information display
Post by G6MNJ » Wed Dec 29, 2021 5:45 pm
So I am right in thinking :-
timers:
USERTRIGGER: 10
PROGRAMTRIGGER: 10
represent 10 second time outs for the MER/dB Report and if so could we make these 60 on our repeater?
Paul G6MNJ
MW0RUD
Post by MW0RUD » Thu Dec 30, 2021 12:43 pm
Yes, USERTRIGGER is the timeout for when you press select on the remote, PROGRAMTRIGGER is the timeout when it activates itself, both in seconds.
Tim MW0RUD
G6MNJ
Post by G6MNJ » Thu Dec 30, 2021 2:43 pm
I read the earlier comments regarding editors - I presume I can edit this with nano can I or that too dangerous too?
Paul
Post by G8GKQ » Thu Dec 30, 2021 5:12 pm
Paul
nano would be my choice from the command line. I use it a lot with Ryde and Portsdown.
Post by g0mjw » Thu Dec 30, 2021 5:23 pm
I would use vi (or vim) but expect I am in a bit of a minority there.
Post by M0DTS » Fri Dec 31, 2021 9:56 am
You are Mike, i just can't get away with vim.
DL5BCA
Post by DL5BCA » Thu Feb 24, 2022 7:11 pm
Hello @all,
I think this has already been mentioned somewhere, but I can't find it again.
Is it now possible to use both inputs of the SAT tuner in scan mode?
E.g. upper for 23cm, lower entrance for 13cm?
I always have crazy ideas.
Please don't be surprised.
Post by M0DTS » Fri Feb 25, 2022 10:26 am
No I don't think so.
But you can send remote tune commands with specific scan parameters either on the Ryde itself or over LAN.
See github example:
https://github.com/eclispe/rydeplayer/b ... orktest.py
Post by g0mjw » Fri Feb 25, 2022 12:15 pm
You could re-write the code to do that, but not at the same time. This is a one channel at a time receiver. If you want to do this it might be better to use the WinterHill board.
DL5BCA
Post by DL5BCA » Fri Feb 25, 2022 4:13 pm
Thank you for the answer.
of course I was thinking of scanning sequentially, similar to scanning to different frequencies on the QO100.
First Ryde scans the SR 1000kB and 333kB on the upper input at 23cm, then the SR 1000kB and 333kB on the lower input at 13cm.
