Goonhilly Spectrum Stream
EA7KIR
Post by EA7KIR » Wed Aug 25, 2021 7:17 pm
I've got this far, but now I need to ask for someone to tell me the correct way to access the Goonhilly FFT stream.
I'm hoping to add it into this client/server system I'm working on. Thank you.
Michael EA7KIR
G0NMY
Re: Goonhilly Spectrum Stream
Post by G0NMY » Thu Aug 26, 2021 11:04 pm
Hi Michael,
Is this what you are looking for?
https://eshail.batc.org.uk/wb/
As if you are after connecting to the Goonhilly stream direct I dont think that option is available.
Probably due to internet bandwidth restrictions.
I'm sure Dave or Noel will verify this.
Hope that helps Michael
73 Mark
http://www.g0nmy.blogspot.co.uk/
¡ʎɐqƎ ɟɟo pɹɐoqʎǝʞ ɐ ʎnq I ǝɯᴉʇ ʇsɐl ǝɥʇ sᴉ sᴉɥʇ
EA7KIR
Post by EA7KIR » Thu Aug 26, 2021 11:18 pm
Hi Michael,
After only 76 views from other members, congratulations on being the first to respond. But no, that is not what I'm looking for. I'm after the raw fft stream that goes to LiveTune and those 2 French guys who don't open source their code. So it is possible and it would only increase the data flow by one user - as with any other use who accesses the web page. Searching through the GitHub undocumented source code is futile. Believe me, I've tried.
Michael EA7KIR
F4DVK
Post by F4DVK » Fri Aug 27, 2021 4:40 am
I don't know programming, but maybe there is some information here:
https://github.com/F5OEO/datvplutofrm/b ... /lib/wf.js
Stephane
Post by g8gtz » Fri Aug 27, 2021 8:22 am
Worth taking a look at Rob M0DTS quick tune github https://github.com/m0dts/QO-100-WB-Live-Tune
If not, I'm sure Rob or M0DNY will be able to help.
EA7KIR
Post by EA7KIR » Fri Aug 27, 2021 9:44 am
Stephane
Thank you Stephan. It's difficult to see what's going on, but it should help.
I sent an email to Rob M0DTS a few days ago. Perhaps he's on holiday.
Thus far, I know I get a continuous stream from wss://eshail.batc.org.uk/wb/fft, but I've yet to discover how its packed. A couple of sentences that explain what's going on would be extremely helpful. Anybody?
Michael EA7KIR
G0NMY
Post by G0NMY » Fri Aug 27, 2021 10:02 am
Hi Michael,
Why not just put your own dish and lnb up then you could capture it all and stream it how you like, and with a lot less internet lag.
Then you can be a Spanish guy who doesnt open source his code!
73 Mark
EA7KIR
Post by EA7KIR » Fri Aug 27, 2021 10:38 am
73 Mark
When I'm happy my software is ready, I'll splash out the dosh and buy a dish and all the other stuff. I'm aware it might be possible to source the spectrum data directly from the Pluto, so (in theory) all I'll need to do is change an IP address.
73 Mark
I'm not Spanish. Check out my website https://michaelnaylor.es. There's a link to my GitHub page where the source code will be published. At present, you'll only see the README file, because the code has memory leaks that are proving difficult to solve.
Michael EA7KIR
G0NMY
Post by G0NMY » Fri Aug 27, 2021 10:40 am
I know youre not Spanish Michael, I was pulling yourleg ;-) :D
Post by G4EWJ » Fri Aug 27, 2021 12:38 pm
I don't know the exact specification of the spectrum stream, but from observation:
Each scan sends a block of 1844 bytes
This is 922 16-bit samples in low-high format
The last two 16-bit samples are zero
Sample zero is at 10490.500MHz
Each sample represents 10000 / 1024 = 9.765625kHz
Sample 919 is at 10499.475MHz
The noise floor value is around 10000
The peak of the beacon is around 40000
