I'll be on from home in the morning on 146.500.  Also got 4m and 70cm.  IO91wi; Carshalton-on-the-Hill.  I think I'm on Zello under my callsign.
Martin - G4FKK
						Low band + 5.6GHz July activity weekend
Re: Low band + 5.6GHz July activity weekend
It was not the most productive outing but i did manage a few QSO's
Fortunately the thunderstorms passed just to the west of me, packing up was only just completed before the downpour started!
6m:
SWR was poor across most of 6m band and the only reason seems to be proximity to the van de-tuning it LF.
I couldn't lift the mast up with it fitted right at the top so had to compromise - smaller 6m yagi required!
1x 1-way QSO with Clive G4FVP at 50.6MHz, it was some 10dB worse at 51.7... probably a combination of both our antenna gains at this freq.
I plan to plot a sweep of gain vs freq for my 5el LFA Yagi, could be interesting.
2m:
1x 2-way qso on 146MHz with Clive, no problems there.
Only my carrier was detected by the more southern stations, poor conditions.
Mike's signal was detectable but only ~1dB/noise on the portsdown band viewer.
6cm:
A nice surprise was Bob, G4PDF who went out portable and we worked 106km path at P5 both ways on 6cm
6m:
2m:
6cm:
