3.4ghz
m1cdq
3.4ghz
Post by m1cdq » Wed May 26, 2021 1:59 pm
how do i set up the portsdown 2020 to use a c band lnb 5150 LO for freq 3404mhz
i can change the lnb offset 5150000 but it wont let me set up the actual freq
Re: 3.4ghz
Post by radiogareth » Wed May 26, 2021 2:12 pm
If you have a Ryde is does it for you when you choose 3.4 as a pre-set. It even swaps to the other input.
It may be possible to reverse-dig the Ryde settings and transfer over, Longmynd being basically the same software?
m1cdq
Re: 3.4ghz
Post by m1cdq » Wed May 26, 2021 2:41 pm
its for a portable portsdown rx
Re: 3.4ghz
Post by radiogareth » Wed May 26, 2021 3:02 pm
Yes, I understand that.
When I was experimenting across the shack I found 3.400 GHz was coming out of the LNB at 1750MHz.
Hopefully that will help set things up. If you have a SDR to locate your down-signal from LNB signal on 3.4 that's a big help working things out.
MW0RUD
Re: 3.4ghz
Post by MW0RUD » Wed May 26, 2021 3:08 pm
Unfortunately the LO offset functionality is not in LongMynd so isn't shared between Ryde and Portsdown
Tim
Re: 3.4ghz
Post by G8GKQ » Wed May 26, 2021 3:25 pm
The Portsdown RX is only set up to use a downconverter for QO-100. For all other downconverted bands, you'll need to do the maths and tune the receiver to the IF frequency.
For contests, where I use 5 different downconverters, I write myself a cribsheet of what IF to use for the common ATV frequencies on each band. It seems to work OK!
