Hello
I've transmitted and received DVB-T across the shack.
Great and it worked 1st time.
What are the IARU Region 1 experimental frequencies on 29 and 50 MHz that the club recommends? With which SDR can we transmit these?
David M0YDH
Knucker frequencies
Knucker frequencies
- DVB-T test at M0YDH
- 20210508_122022_copy_1008x567.jpg (185.46 KiB) Viewed 3313 times
Re: Knucker frequencies
Try this link... viewtopic.php?f=91&t=7166 for the frequencies...
And this for the compatibility matrix https://wiki.batc.org.uk/Portsdown_4
Hopefully see you there soon!
Graham G3VZV
Graham G3VZV
Yes Graham - thanks.
29.25 and 51.7 MHz DVB-T 333KS is noted. I read the article in your link but must have missed the device which will work on 10m. I assume that a Lime mini will work on 6m.
David M0YDH
David M0YDH
