New Graphics Software to Generate Mpeg-TS Streams
F1EJP
Post by F1EJP » Fri Apr 02, 2021 7:59 pm
Hello all,
Currently under test and development of a new version in graphical software V2.31
It comes with everything you need plus a few additional options!
No need to have FFMPEG anymore
Input for OBS with virtualCam or vMIX or ip flux
Coding with NVIDIA GPU or INTEL or Soft
New compression enhancements by providing optimized default settings for compression.
Currently being tested :roll:
Dominique
F1EJP
Configuration
G7JTT
Re: New Graphics Software to Generate Mpeg-TS Streams
Post by G7JTT » Sun Apr 04, 2021 2:05 am
Looking good Dominique.
g4saq
Post by g4saq » Sun Apr 04, 2021 12:00 pm
A great idea, Dominique. Good luck with your development, I look forward to trying it.
Russ
G7VVF
Post by G7VVF » Mon Apr 05, 2021 7:42 am
I agree. This is very good Dominique. I've only been playing with this stuff for a few months and I've gone from scripts in OBS and manual calculations of bit rates to this, we are moving forward very quickly. I look forward to using it.
Duncan
G7VVF
F1EJP
Post by F1EJP » Thu Apr 08, 2021 11:26 pm
Hello
New screen
73 Dominique F1EJP
Post by g0mjw » Fri Apr 09, 2021 9:19 am
Hi Dominique
Is it ready for testing yet?
F1EJP
Post by F1EJP » Wed Apr 14, 2021 10:02 pm
Currently in the process of being finalized before testing
73 Dominique F1EJP
Jabi
Post by Jabi » Thu Apr 15, 2021 6:44 am
Dear Dominique:
I am ready for "work" and testing your software.
73,s de Jabi, ea2aru.
Post by g0mjw » Thu Apr 15, 2021 8:28 am
We are on version 2.46 already? How did I miss this ;)
I am looking forward to testing it.
1 - Can you explain the name?
2 - Does it use ffmpeg DLLs or is it based on something else?
3 - It would be nice for it to be usable as a plugin to OBS. A bit like this https://obsproject.com/forum/resources/ ... tudio.826/
F1EJP
Post by F1EJP » Thu Apr 15, 2021 9:44 pm
Hello
- Version 1 was the batch script ;)
- I changed the name to a more explicit name
- it uses ffmpeg but no need to install it because it is included
We can code with FFMPEG with the support of an NVIDIA graphics card or a recent Intel processor with GPU or in software.
The source can be OBS or vMIX or an already encoded iP stream.
For each value of SR, depending on the configuration, the software proposes tested and approximately optimized default values VIDEO/AUDIO.
>> we can go down to very low speeds of the order of 88kb / s which should allow transmissions in DVB-S2 16PSK SR25
Still in test soon available
73 Dominique F1EJP
