Programming the FT2232H
G8YTZ
Post by G8YTZ » Sat Feb 13, 2021 5:02 pm
I'm having some issues programming a band new FT2232H from Digikey.
Screenshot 2021-02-13 170128.png (156.02 KiB) Viewed 16715 times
Screenshot 2021-02-13 170005.png (35.3 KiB) Viewed 16715 times
Re: Programming the FT2232H
Post by g8gtz » Sat Feb 13, 2021 6:03 pm
Having programmed over 1,000 of these I can tell you that's not right!
Either you have other FTDI devices plugged which it found or what you think is an FT2232H just isn't one....
G8YTZ
Post by G8YTZ » Sat Feb 13, 2021 11:38 pm
Thanks Noel,
Do I have to supply power, or is USB power enough?
BR
G8YTZ
Post by G8YTZ » Sun Feb 14, 2021 12:12 am
Noel,
I popped the unit in a Minitiouner and programmed it ok. Do these settings look correct?
Screenshot 2021-02-14 001036.png (204.13 KiB) Viewed 16653 times
Post by g8gtz » Sun Feb 14, 2021 8:44 am
For future reference, the USB module must be plugged into a PCB to be programmed (shorts out 2 power pins) but power does not have to be applied to the PCB as the USB supply is adequate.
Difficult to say, presume you used the xml file from here for MiniTiouner https://wiki.batc.org.uk/MiniTiouner_ha ... USB_module or here for Knucker https://wiki.batc.org.uk/Knucker#USB_Module
G8YTZ
Post by G8YTZ » Sun Feb 14, 2021 9:05 am
Thanks Noel,
The successful programming (at least it said "finished") was with the module plugged in. Actually its a for Knuckler, the board is populated, just awaiting the tuner now.
I'm hoping my panel kit will also fit, failing that I'll get the rear panel reworked.
Is it intended to support the OLED display on the Knuckler, either now or in the future?
Justin.
Post by g0mjw » Sun Feb 14, 2021 10:04 am
I would not bother with the OLED. Seemed like a good idea at the time. Mine is showing burn-out, I expect most are by now. The rear panel is different from the V2 Minitiouner as the tuner has a different connector spacing.
G4FRE
Post by G4FRE » Sun Feb 14, 2021 11:11 am
Both of mine are still working fine, even after rough portable operation. They are very useful.
g4fre
G4FRE
Post by G4FRE » Sun Feb 14, 2021 11:14 am
or, like me G8YTZ received the special Digikey version of the FT2232H with a critical resistor missing from the board!
They shipped a replacement which was here in 3 days
G4FRE
G8YTZ
Post by G8YTZ » Sun Feb 14, 2021 5:59 pm
That's a point, is the additional resistor on the FT223H board required for the Knuckler as per the later versions of the Minitiouner?
