BATC STREAMER?
BATC STREAMER?
Has the BATC Streamer stopped working?
Martin
G8KOE
Martin
G8KOE
Re: BATC STREAMER?
No - it appears fine our web page is showing 3 streams ET not streaming.
http://www.ddrcbootsale.org/g4ddc/streaming.htm
or
https://batc.org.uk/live/gb3tz
What is the problem you have ?
or
Re: BATC STREAMER?
It Just says connecting.
Martin
G8KOE
Martin
G8KOE
- Connecting.JPG (70.88 KiB) Viewed 6433 times
Re: BATC STREAMER?
Has anyone got a link to a coverage map of GB3TZ? I can put a decent signal into Dunstable on 2m as despite being in a valley, I can see the Crystal palace tower which is bang on line from me to GB3TZ. I will be able to run 40 watts DVBS power on 13 and feed it into a 46 element I can aim out of the loft window straight at it. I'm JO01AI.
Why 4MS? Surely 1MS would give similar accessibility (set top boxes) but better coverage?
Gareth G4XAT
Gareth G4XAT
Re: BATC STREAMER?
Hi Gareth,
At the moment the 13cm input is being blocked by other equipment installed on site, try 437MHz Digital DVB-S 2MSym
Steve
Steve
Re: BATC STREAMER?
Hi Martin I had the same issue yesterday, will check later when I'm home if it's still doing it.
John G7JTT
John G7JTT
Re: BATC STREAMER?
Yes, there is a streaming problem displaying "connecting" if Flash is the source. HTML 5 is NOT working at all!
Luke VK2LGW
Luke VK2LGW
Re: BATC STREAMER?
Yep back home and streamer just says connecting no video or sound either tonight. Tried on my phone and laptop using various browser's. Is it a DOS attack again ?
John G7JTT
John G7JTT
Re: BATC STREAMER?
Using Flash here and streaming is fine.
Steve
Steve
Re: BATC STREAMER?
Just re-tried on BATC site, html5 just says connecting, but flash is fine and audio OK.
Flash still working here
Firefox OK, chrome says flash blocked, so click on exclamation mark area next to address and allow flash.
