Portsdown 4 with Pluto
VK3IE
Post by VK3IE » Tue Aug 25, 2020 9:38 pm
What are the current limitations of the Pluto as compared to the Lime.
Current new Firmware with Lime working well (local setup) Just do a new SD saves a lot of weird stuff from happening.
Not seeing many Setup\FAQ on using Pluto with Portsdown
Re: Portsdown 4 with Pluto
Post by G8GKQ » Wed Aug 26, 2020 3:01 pm
The Pluto modes are still somewhat experimental in the Portsdown - hence the lack of documentation.
The Pluto modes are:
  • H264 only. No MPEG-2 or H265
  • 4:3 SD or basic 16:9 only. No 720p or 1080p
  • You can set and store (for each band) Pluto relative power on a range of 0 to -71. This approximates to dBm, but is plus or minus 10 dB.
  • I have seen it work well on symbol rates between 125 and 1000 kS.
  • DVB-S or DVB-S2
  • Video source Pi Cam, Comp Video, C920, Test card or Contest.
  • Pluto and RPi GPIO PTT switching implemented, but the test card mode overuns after deselction of transmission
  • Only tested with F5OEO's "for the brave" Pluto firmware (FIRM2101RC of 5 February 2020) .
VK3IE
Post by VK3IE » Wed Aug 26, 2020 11:13 pm
Thanks, now I have a feel of what to look for.
Lime is working 4 ks and upwards locally real well.
Just need to get some AMPS happening (watts) for vk3rtv
Cheers
F4DVK
Post by F4DVK » Thu Aug 27, 2020 4:50 am
Dave,
Have you tested in DVBS with a 5/6 or 7/8 FEC?
Thank you,
Stephane.
