70.5 - 71.5 MHz
Re: 70.5 - 71.5 MHz
Post by g0mjw » Tue Jun 30, 2020 9:46 pm
g7ntg wrote:
Tue Jun 30, 2020 6:39 am
My upconverter is in CQ-TV 267
Its a modified nooelec ham-it up with built in LO
I tried that too. You need to modify the filters but then it works. It doesn't have any front end gain though, so needs a preamp in front. Narrow filtering too is a good idea given all the strong signals kicking around.
G1LPS Terry
Re: 70.5 - 71.5 MHz
Post by G1LPS Terry » Wed Jul 01, 2020 4:55 pm
Thanks Steve and Mike for the info
Terry
G4FRE
Re: 70.5 - 71.5 MHz
Post by G4FRE » Wed Jul 01, 2020 7:28 pm
I modified a G4DDK Nacton 70/28MHz Transverter for 71/437MHz operation with an AD4351 local oscillator which works well. See http://g4fre.com/Nactontv4m.htm
I also converted another G4DDK Nacton 70/28MHz Transverter for 51/437MHz operation with an AD4351 local oscillator see http://g4fre.com/Nactontv6m.htm
G4FRE
Re: 70.5 - 71.5 MHz
Post by radiogareth » Thu Jul 02, 2020 12:04 pm
Having looked at the conversion it crossed my mind that each Nokia Dolphin amp has 3 identical input strips which may well tune to the 3XXMHz frequencies mentioned and already have a mixer on each one (wrong place I expect). The wonderful world of surplus......
2020-07-02 12.54.52.jpg (169.91 KiB) Viewed 20175 times
