Langstone Update
Re: Langstone Update
That's where F5OEO's firmware comes in.
No problems, will check for diodes and as the signals are on the RPI and I'll be integrating my lone SMA relay into the Langstone box, its all going to work
Ran it up on my R&S analyser today, 50 & 70 have lots of strong harmonics (think I read its due to being squarer at those freq's...) and got the following powers.
6m -8.4dBm
4m -5.3dBm
2m -0.9dbM
70cms +2.0dBm
23cms -1.1dBm
13cms -1.4dBm
On 6,4&2 my little +35dB amp gave 1 watt out. Very handy.
I can't measure power above 2.7GHz but have a purple heatsink Stealth amp that says -6dBm drive max on its data sheet and also an IONICA PA for the band. I've previously used the Pluto with DVBExpress for DATV tests on 3.4 GHz so I don't think I can overdrive either amp with the Pluto but it would be handy to know what peoples Pluto gives out at 3.4GHz on Langstone - e.g. FM.
TX power control works a treat too.
6m -8.4dBm
4m -5.3dBm
2m -0.9dbM
70cms +2.0dBm
23cms -1.1dBm
13cms -1.4dBm
Hi Gareth
The power levels that I measured at 2.4 and 5.7 GHz are on this wiki page https://wiki.microwavers.org.uk/Langstone_Projec
Your measurements seem to be a little lower than mine, but within amateur test equipment tolerances.
Thanks Dave, I'll start with 50% power then into a DL and see what Vf from the amp gives. The Data sheet implies some approximate values as a guide.
I've also been wondering about the Daffodil Audio dongle - mainly as it has speaker drive capability and buttons for vol and mute. Its the C-Media one listed below:
pi@raspberrypi:~ $ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 0456:b673 Analog Devices, Inc.
Bus 001 Device 005: ID 045e:0084 Microsoft Corp. Basic Optical Mouse
Bus 001 Device 007: ID 0d8c:000c C-Media Electronics, Inc. Audio Adapter
Bus 001 Device 003: ID 8086:0808 Intel Corp.
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
With NEITHER plugged in I get this:
So it looks like it's the 'Intel Corp' (bet its never been near Intel!!) unit that works 'native' with the Langstone.
At this point its 'go and google' audio issues on a RPI, but I don't want to mess up whats working. Booting the Langstone with JUST the Daffodil plugged in stops the FFT and freq display so I'm out of my depths here
I might just have to add a small audio amp.....but a bit of digging found the same daffodil card.
https://computers.tutsplus.com/articles ... -mac-55876 although for an earrlier RPi......
The PTT info was from Evariste but it's all documented in the ad9361 datasheet.
iio_device_debug_attr_write(phy,"direct_reg_access","0x27 0x00"); //ptt off
iio_device_debug_attr_write(phy,"direct_reg_access","0x27 0x10"); //ptt on
iio_device_debug_attr_write(phy,"direct_reg_access","0x26 0x10"); //maybe required to set GPIO pin to manual control mode.
I had tested and it worked but i accidentally overwrote the code today with the updates ...!
There are three other GPIO 'bits' left for band switching too
Hi Rob,
That's interesting, my interpretation of the datasheet was that you could not access the debug attributes with libiio. Sounds like I was wrong. I will add it to the next release.
I have been doing a lot of rewriting today to split the Tx and Rx GNU Radio Flowgraphs into separate python tasks. I can then freeze either one when its not being used and reduce the CPU loading. It seems to have fixed the Latency drift we were getting. I think running both Tx and Rx all the time was overloading the Pi. I can still run both in sat mode for monitoring the downlink while transmitting but normally only the Tx or the Rx needs to be running.
Colin.
Colin.
Gareth,
if you enter aplay -L it will display a list of all the audio devices.
The code is currently using 'hw:CARD=Device Dev=0'
if you can identify the hw: entry for your audio dongle make a note of it. The 'CARD=' part is the name of the device. The recommended one is called 'Device' but some others seem to be called 'Headset' .
You can then edit the SSB_TRX.py file to change the name.
I will try to work out a way of automating this.
Colin.
Colin.
Ok that's good, i wondered if it was possible to control the parts of the flow graph, good to hear it is.
Noted the delays seem to have disappeared.
The listing of audio devices is a pain, was looking at that too, not all info is in one place!
I've just tried the GPIO code again and it works fine.
Will be testing a mast mounted PLUTO on 3.4GHz tomorrow.. hopefully it all works ok!
talking about PTT, do you think it's worth to have the GPIO PTT signal to be emitted several millisecond before the pluto PTT command?
this in order to switch on the antenna relay and amplifiers before the pluto starts transmitting.
a sort of built-in sequencer...
and, if someone is going to prepare a new GPIO breakout board, one or more optocouplers for PTT or other commands could be added?
thanks
Claudio
thanks
Claudio
i2NDT Claudio
Dalmine, Italia
Dalmine, Italia
Hi Claudio,
That’s already happening. There is a built in delay between the PTT output and the RF output.
However I would still recommend people use an external sequencer in any amplifier.
Colin
Colin
