Langstone Discussion Forum
Hi Alex,
The project only supports the Raspberry Pi touchscreen at the moment.
To keep the code simple the hardware needs to be kept under control. Especially at this early stage.
Maybe later someone will adapt it for other displays.
Colin.
Colin.
Colin
Great, no issue. Another toy to look for.
Regards
Alex
Regards
Alex
hmmm ... what if we could connect an hdmi in parallel ?!?
either for just duplicate the touch screen ...
or for using the second screen for a digimode software
the rpi should have enough power to also use a digimode in parallel
freedv could be added (usb/lsb/cw/fm/freedv)
or other digimodes (cw decoder and keyer ... psk rtty etc)
greetz sigi dg9bfc
greetz sigi dg9bfc
Langstone Squared? (2 Langstones in a two-way??).
Just had a two-way SSB QSO on 70.205MHz with Martin G4FKK. Nothing special there except we were both using Langstones each end
Noisy band my end
Noisy band my end
Hello, everyone
Just assembled one, but difficulties with audio
I've got several USB Dongles , Blue ones like, shown in picture
Allthough recognized by the Linux, Langstone does not start up properly
Can you specify for which dongle it is written ?
There seems to be quite a difference
Tnx 4 answer
JP, ON7MA
Tnx 4 answer
JP, ON7MA
- 3D USB Dongle.jpg (22.92 KiB) Viewed 224466 times
It is written to use one of these
But some people have used other types. It may be necessary to edit the files Lang_TX.py and Lang_RX.py to change the device name. It is currently set to ‘ HW:Device ‘
If you log into your Pi and enter ‘ aplay -L ‘ it should give a list of device names. Look for the ones that start ‘ HW: ‘
Collin,
Tnx for answer, yep, did the trick..
in the python scripts you are looking for "hw:CARD=Device, DEV=0"
but the 3D dongle was named "hw:CARD=Set,DEV=0", so I changed, and rerun'd with succes
Now I have noise, for ex on FM, but the Sound = chopped in a freq of 3-4 Hz.. is this normal ?
JP, ON7MA
JP, ON7MA
Hi JP,
No the sound should not chop. Someone else had a similar problem and eventually replaced the Dongle.
It may be that some dongle sample rates are not very accurate. That can cause chopping of the audio because it runs out of samples.
At the moment I do not know how to fix that problem!.
Colin.
Colin.
OK, Colin
I just read Claudio had the same problem
After replacing his dongle, it worked
Mine is ordered..
I'm waiting for it
Tnx, Jemp
Mine is ordered..
I'm waiting for it
Tnx, Jemp
hi Jemp,
the dongle I used is exactly the same as yours...
with the suggested one it's ok now.
unfortunately the UK ebay shop where I bought it lists another model now!
Claudio
Claudio
i2NDT Claudio
Dalmine, Italia
Dalmine, Italia
