Intelligent Stream Control (Adobe Encoder)
g1ugj
Post by g1ugj » Wed Jun 08, 2011 10:49 pm
Thought this maybe usefull for those who maybe mobile streaming or anyone with bandwidth limitations.
Or other situations where you want more control over the stream.
What i have put together is a little package that controls the AE stream depending on who is actually viewing the webpage.
This assumes that you are useing a webhost that has PHP scripting, and useing the BATC plugin on your own website.
the software is in 2 parts:-
1/ is the main application that sits on the PC that is running the encoder.
2/ is the PHP script that sits on the webserver.
[webserver side] What happens is that when a visitor looks at your camera webpage the script creates a file with a timestamp.
[PC encoder side] The application picks up on this timestamp and tells the encoder to start streaming, after a period of time (10 minutes default) it will then stop the stream.
Effectivley we have changed the stream PUSH into an ON DEMAND. ( why stream if no-one is watching :o )
Presently the software is version 1.5 and available at my site http://g1ugj.net
I am looking at expanding the software to give more control over the encoder.
73's
G8ADM
Re: Intelligent Stream Control (Adobe Encoder)
Post by G8ADM » Fri Jun 10, 2011 10:45 pm
This sounds very usefull. I would like to try out your software.
Unfortunately your version 1.5 is error 404, not found.
Help,
Dave.
g1ugj
Post by g1ugj » Sat Jun 11, 2011 9:43 pm
Oppps :roll:
Please try again
G8ADM
Post by G8ADM » Mon Jun 13, 2011 10:18 pm
Thanks,
Dave.
Return to “Streaming”
