comp video output
comp video output
I have managed to sus out comp video output. So i can output comp video for analog 5.6ghz
But if i select output to comp vid and input IPTS in it does not work.
it goes to composite video output menu(4)
wiht choices of picam, Contest, TCAnim, Testcard,Snap
so it looks like i cannot use iptsin to ouput comp
Re: comp video output
Comp Video output simply replays the camera or any image sent to the framebuffer.
For IPTS in, the digital video is routed straight to the modulator software and never decoded, so is not available for display (and hence video output).
You could write your own application to do it; I think that omxplayer could possibly display the IPTS in given the correct parameters, but it all depends on your video source.
going to have to sort some vga to comp hardware out for the pc . my plan was to use the portsdown with obs . As im going to mount a 5.6ghz tx and rx on my rotator on my roof. using OBS to the ports down then video up the the mast mounted tx
Im baffled. ( not unusal as it happens every day )
I saw that composite video was available when using element 14 7" screen. I thought great, i can display the repeater streams using my Portsdown on one of the monitors I have in a group of 4. It will make a nice addition when displaying my testcard on one. GB3TT beacon on another, GB3EY repeater on another and Whatever I want off the Portsdown repeater stream. Was I expecting something that's not possible ? ( oops my wife came to mind for a moment ). I digress !
So, on hooking up video OUT from the "shaft" of the 4 pole socket. together with ground ring 2. I was expecting to see streaming video on my large monitor. Alas NO, I get 5 lovely colours towards each corner of the monitor. 2 shades of blue and a magenta , green and a yellow.
I tried a different lead i made up before that i know works on my other setup with a small waveshare screen and that lead produces same result.
I tried "source" as my testcard and "output to" Comp Vid but still no luck.
By the way. Sound is working OK from the same lead. Comes out of the little speaker on front of case in photo.
Maybe I'm expecting it to do something it won't. or not using the menu's correctly. Any help is appreciated.
Many thanks Ken
Many thanks Ken
- IMG_20200127_121400_resize_19.jpg (323.43 KiB) Viewed 4614 times
on portsdown
menu 3
system config
7 inch vid set to "Enable"
menu 3
system config
Do you ever go in a supermarket and you can't see what you want yet it turns out its right in front of you , once its pointed out.
Thanks Roger for that information. Now Working of course. I was blinded by the light
Best regards Ken
Ken
The reason for having to positively select it is that I did not want the process that duplicates the screen image running all the time (when other displays are being used). Not sure if it would stop something else working.
M1CDQ - thanks for supplying the answer!
Dave, The whole thing is awsome. Nuff saidG8GKQ wrote: ↑Mon Jan 27, 2020 3:55 pmKen
Ken
