obs and ffmpeg help
m1cdq
obs and ffmpeg help
Post by m1cdq » Mon Nov 11, 2019 7:16 pm
Im trying to set up obs and ffmpeg
I thought i had it sorted. but once i get it running and recording to udp
I try and view the stream with vlc . I am unable to see it on vlc on the same pc or pc on same network.
udp://230.0.0.11:20000 on both obs and vlc dont get a thing
I have this on the OBSto UDP/ts screen
Input #0, mpegts, from 'udp://230.0.0.11:20000':
  Duration: N/A, start: 28.880000, bitrate: N/A
  Program 1
    Metadata:
      service_name    : Service01
      service_provider: FFmpeg
    Stream #0:0[0x12c]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuvj420p(pc, bt709/unknown/unknown, progressive), 576x324, 25 fps, 25 tbr, 90k tbn, 50 tbc
    Stream #0:1[0x12d]: Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, mono, fltp, 35 kb/s
Output #0, mpegts, to 'udp://192.168.0.12:10000:10000?pkt_size=1316&bitrate=372100':
  Metadata:
    service_provider: QO-100
    service_name    : M1CDQ
    encoder         : Lavf58.12.100
    Stream #0:0: Video: h264 (High) ([27][0][0][0] / 0x001B), yuvj420p(pc, bt709/unknown/unknown, progressive), 576x324, q=2-31, 25 fps, 25 tbr, 90k tbn, 90k tbc
    Stream #0:1: Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, mono, fltp, 35 kb/s
Stream mapping:
  Stream #0:0 -> #0:0 (copy)
  Stream #0:1 -> #0:1 (copy)
Press [q] to stop, [?] for help
frame=24781 fps= 25 q=-1.0 size=   45144kB time=00:16:33.81 bitrate= 372.1kbits/s speed=0.994x
I have been following the wiki
https://wiki.batc.org.uk/OBS_-_Open_Broadcast_Studio
im using windows 10 64bit
m1cdq
Re: obs and ffmpeg help
Post by m1cdq » Mon Nov 11, 2019 9:00 pm
not sure what the issue is. but it might be due to the pc having vmbox and 2 gigabit adapters.
but a cure or workaround
OBS i bound it to my main network IP address
File--settings---advanced----scroll down to network --- bind to IP (mine is "Ethernet 192.168.0.10")
vlc the stream address is now udp://192.168.0.10@230.0.0.11:20000
this works when i use it on any PC across the whole network at home
