Spectrian 30 watt snow flake mod ?
Hi Guys,
some time ago I stumbled across a 'snow flake' mod for the pyrojoe 30 watt Spectrian to lift its power from 25 watts to 30 watts when used for DATV uplink.
Ok, going from 25 to 30 W probably won't make any noticeable difference - but try as I might I can't find this information.
Does anyone have a link ?
73 Tim
73 Tim
Re: Spectrian 30 watt snow flake mod ?
I don’t have a link but the point on the amp that responds to snowflaking is on the output of the final FET, where the line takes a 90 degree turn before running down the end of the board. I found a fairly large snowflake (4mm square?) attached to the 45 degree section worked for me. It actually slightly overlaps the adjacent ground plane so I insulated underneath it with kapton tape.
Thanks, once I have the complete unit built up and working I'll check the power as standard then with the snow flake - luckily I have some kapton tape.
Regards Tim
Regards Tim
Mine was 21W before and 30W after which is a worthwhile gain for DATV.
I optimised the tuning at reduced power, about 10W output.
Suggest you take a look at page 15 in the new CQ-TV 263...
That article is for the 75W amp Noel. The 30W one is a different beast.
[UKMicrowaves] Spectrian 30W amp problem.
Taken from https://groups.io/g/UKMicrowaves/topics ,
the image above is re-hosted by me The text was :
______________________________________________
Hello Colin and other readers.
I feel that I can't assist your problem any more than the help you've
already received. But I wanted to add that I do have one of these
amplifiers working perfectly well at 2403 MHz, the centre of amateur
activity here in VK.
However, I did go through the whole amplifier chain trying to find
locations for solderable tabs ("snow flaking"), hoping to make it work
better at this further-out-of-band frequency. The interesting thing is
that I did find one sensitive/responsive point and it was between the
final device and the output port, where the microstrip track takes a
left hand turn - see attached '385s image. At 2403 MHz, 10 mW input
delivered 31 Watts output following this small addition.
It was also interesting that there seems to be a layer of some plastic
material everywhere which has to be melted away before the solder will
'take' - it makes the resulting soldered joint less than good looking!
Only for interest's sake, I'm also attaching a general image of the
whole amplifier.
I wish you well with rising to your challenge!
--Doug Friend, VK4OE.
Ex G6ANG/T and G8EAO
Thank guys, just what I was looking for.
Hope yo have my PA up and running under test in a day or so, then I have to make the dual feed and align etc.
All in all it's coming together....
73 Tim
73 Tim
Please let us all know how you get on Tim.
I have just purchased one of these from the seller on ebay and have measured 20W out for 10mW in on 2407.750 Mhz.
The photo attached of the PA shows that a snowflake was added at some time either on manufacture or later.
So to optimise do I move it or add another ?
73 Tony G4AXN
73 Tony G4AXN
- cu PA stagecrop.jpg (215.25 KiB) Viewed 10756 times
When you try to add another the original one will probably come off anyway. The exact size and location will be different for each amplifier so it is a trial and error technique.
