Either we have a new pope - or my buck converter is faulty?
Keith G8VMP
White smoke....
I've just completed the hardware build and started testing voltages.
The lowest voltage I can get form the buck DC-DC converter is 4.07v and there is 16v on the input.
I cannot physically turn the pot lower its at the end of its travel.
I expected 4.07v to be ok and put a jumper on J2
Very shortly there was smoke coming from the zener diode and I checked the voltage - 6.1v not good!
I assume this is a buck converter problem? or anything else it could be? Input voltage?
If so, where is the best place to get a reliable DC-Dc converter. This one was £1.96 from ebay
Will anything else be dead now?
Many thanks for any advice
Keith
Keith
Keith G8VMP
Re: Either we have a new pope - or my buck converter is faulty?
I think zener is dead too - just tested 4ohms in each direction.
Hopefully it shorted all the voltage out so the regulators are ok.
There seems to be a few posts of issues with these DC-DC boards, I need to buy one for my kit but I cannot find a known good seller for this particular board or a known good version.
It might be worth putting the info on here where yours was obtained.
Good luck with the build and hope it's just the zener!
Keith G8VMP
I got the first one that blew from ebay seller alltopnotch
Second one will be from ebay seller booskibits (although i think someone already had a failure from them)
I'll report back when it arrives.
It was just the zener that blew fortunately.
Keith G8VMP
Well there's a thing!
The one I got today from booskibits worked but alltopnotch failed!
Whereas its the opposite for G8DPH
Looks like its a matter of luck then!
