mini T s/w using codeweavers crossover
Richard-g8jvm
Post by Richard-g8jvm » Thu Mar 21, 2019 5:40 pm
has anyone tried running MiniTs/w in Codeweavers Crossover on Linux, its a sort of extention to Wine.
Richard
Richard-g8jvm
Re: mini T s/w using codeweavers crossover
Post by Richard-g8jvm » Fri Mar 22, 2019 4:48 pm
I downloaded the trial version of Crossover 18
and registered on the French DATV site, how long does it take to get the approval so I can download the s/w to see if it will run on
Crossover 18, there is only a limited time before it expires, and other posts regarding geting the s/w indicate ii is a very slow process.
Richard g8jvm
M0SKM
Post by M0SKM » Fri Mar 22, 2019 7:13 pm
If JP doesn't see your post here you might catch him on the Spectrum Monitor chat.
https://eshail.batc.org.uk/wb/
Without a tuner connected the software shuts down.
Steve
Richard-g8jvm
Post by Richard-g8jvm » Fri Mar 22, 2019 7:38 pm
Thanks Steve
Well I guess I can get to the point to see if it will install,
I do know someone locally who has a board , so maybe I could see it it runs on her board.
Richard
Richard-g8jvm
Post by Richard-g8jvm » Fri Mar 22, 2019 9:49 pm
well it installs,
but it doesn't even start to shut down without a board present.
Glad I didn't get any of the boards to build up, it would have been wasted money.
Maybe in a few years time there will be FOSS
Richard
Post by M0DTS » Sun Mar 24, 2019 1:04 pm
try leandvb, it is linux based and will work with an rtlsdr dongle and likely whatever other sdr you have.
Sorry i cant help much with how to work it but is possible for DVB-S and S2.
http://www.pabr.org/radio/leandvb/leandvb.en.html
Richard-g8jvm
Post by Richard-g8jvm » Sun Mar 24, 2019 1:56 pm
Thanks Rob
Its very frustrating when Linux offers so much more that you can do .
An example is the zmodo IP cam I have
It has to IE8 plus plugins to get at the setup for it, but its running linux
Luckily they foolishly left a hardcoded password, so It was an easy telnet hack on port 23
to get in and set the date ect.
I'm sure that many of the commercial sat Rxs that run linux as an internal system can be hacked.
But I cant get any answers from anyone about the sample rate below 1Ms/s .
I cant see it being a hardware problem as its just running slower.
#But I'm stuck with the lack of knowledge on DTV system, thats really gets me miffed
The other problem is those with the knowledge on the whole dont want to share it.
i'll be the queue to be hung drawn and quatered before long on this group
Richard
