Limesdr problem with Portsdown
SM6TLX
Post by SM6TLX » Tue Feb 26, 2019 8:12 pm
Don't know if this ended up in the wrong topic.
But I have problems with LimeSdr mini that I bought from Batc shop.
When I have set up "carrier" it works and lime sdr transmit .
But when I choose something else eg. Dvb-S then it transmit for 2 seconds and then it stops transmitting. I've tried everything, but nothing helps.
/Hakan SM6TLX
Re: Limesdr problem with Portsdown
Post by G8GKQ » Thu Feb 28, 2019 7:58 pm
Hi Hakan
Sorry for the delayed reply - busy times!
I can ask some questions and then make some suggestions, but it is difficult to be sure whether the problem is with your Portsdown hardware or the LimeSDR Mini.
  • Are you using a Powered USB Hub between the RPi and the LimeSDR?
  • Have you tried a different hub and different USB leads?
  • Have you tried the LimeSDR with DATV Express Software on a PC, or with any other transmitting software?
  • Have you looked at the results of the Lime Report on the Lime Config menu in the latest Portsdown software?
  • What transmission mode (all parameters) are you trying (please include a photo of Menu1 on your Portsdown)?
  • What is the firmware and gateware version of your LimeSDR?
Sorry that it is all questions, but I need more information!
SM6TLX
Post by SM6TLX » Fri Mar 08, 2019 2:23 pm
Busy time here too :-)
Are you using a Powered USB Hub between the RPi and the LimeSDR? Yes
Have you tried a different hub and different USB leads? Yes
Yes with Datv Express it transmit normaly.
See pictures.
/Hakan
Post by G8GKQ » Sat Mar 09, 2019 11:05 pm
Hakan
That all looks good.
Running out of ideas, but please could you try plugging the LimeSDR into the RPi directly (no hub, no cable). Also try 333KS H264 and a Lime Gain of 88.
EA3UM
Post by EA3UM » Tue Apr 02, 2019 8:07 pm
Hi Dave
I hope it's the right topic, since the concept is the same.
I repeat the query: (post some days ago)
I have rpi3b +, updated with version 201902250 and I am operating with Lime DSR USB.
With modulation in CVB-S, no problem, but when choosing any of the other options S2 ... it is set to TX for 2 or 3 seconds and stops.
I have the Lime that when updating it by menu 5, option 11, tells me that it does not require updating and everything ok.
I am operating from the console because for lack of space I can not install any display / keyboard.
Is it possible that another type of modulation other than CVB-S can not be configured from the console as in previous versions??
Magi
EA3UM
Post by G8GKQ » Tue Apr 02, 2019 8:27 pm
Hi Magi
I did reply earlier today: viewtopic.php?t=5912&p=18912#p18912
EA3UM
Post by EA3UM » Wed Apr 03, 2019 12:00 pm
Hi Dave, OK
Other information:
In the intervals that the modulation disappears, in the conditions that I have described, in the constellation screen,
the 4 points of the QPSK system disappear and gradually 12 points appear, as if it were a 12QPSK modulation
or something similar.
Later and also slowly, the 12 points disappear and the 4 of QPSK appear, recovering
the reception.
They are data that I believe can be useful
Magi
EA3UM
