Portsdown Stretch 2019 Software
Re: Portsdown Stretch 2019 Software
Post by g0mjw » Thu Feb 21, 2019 5:58 pm
I removed my shutdown button. Now there is an option on the screen the only time you would need it is when the PI has crashed, and then it doesn't work.
Post by G8GKQ » Sat Feb 23, 2019 11:02 pm
Tom
I have rechecked this function on my test rig and it seems to work as expected.
Can you check from the command line whether the process pi-sdn is running?
Can you shutdown from the button on Menu 2?
Does the state of the "SD Button Enabled/disabled" change when you select it?
Is there a possibility that you night have damaged that input pin (static?) on your RPi?
dl6rcg
Post by dl6rcg » Sun Feb 24, 2019 9:09 pm
to your questions:
How can I check this from command line if pi-sdn is running?
Yes, I can shutdown from button in Menu 2.
Yes, the state is changing when I select it. From disabeld to enabeld immediately, from enabeld to disabeld I have to reboot.
I don't know, I am very careful when I touch electronics, my workplace is ESD protected...
73 Tom
Post by G8GKQ » Sun Feb 24, 2019 9:28 pm
Hi Tom
To check whether pi-sdn is running, you would need to log in by ssh (details here: https://wiki.batc.org.uk/Console_mode) and then go to the shutdown menu, Exit to Linux, and then type:
pgrep pi-sdn
If it returns a number, pi-sdn is running. If it simply gives you another prompt, then it isn't running.
dl6rcg
Post by dl6rcg » Mon Feb 25, 2019 4:26 pm
thanks for the info. You must know I am not a Linux expert ;)
I only get back a prompt and not a number. So pi-sdn is not running.
What should I do now?
73 de Tom
Post by G8GKQ » Mon Feb 25, 2019 10:38 pm
Hi Tom
Please could you enable the button (from Menu 3, System Config) and then go to the command line again. This time, type:
cat .pi-sdn
and tell me the response.
dl6rcg
Post by dl6rcg » Tue Feb 26, 2019 6:51 pm
this is the response of my Raspi:
pi@raspberrypi:~ $ cat .pi-sdn
## called by .bashrc at log-on to enable hardware button shutdown
## If this file is in ~, then hardware button shutdown is enabled
sudo /home/pi/pi-sdn 3 2 > /dev/null 2>&1 &
73 de Tom
Post by G8GKQ » Fri Mar 01, 2019 8:39 pm
Hi Tom
What response do you get if you run this command:
It may be that the pi-sdn file is not present on your system. Failing that, I suggest you test the GPIO pin with another program.
dl6rcg
Post by dl6rcg » Sat Mar 02, 2019 10:51 am
the response is:
sh: 1: /home/pi/rpidatv/scripts/shutdown_script.sh: Permission denied
... and the led is on.
73 de Tom, DL6RCG
Post by G8GKQ » Sat Mar 02, 2019 6:50 pm
Hi Tom
That shouldn't happen, and I worry what else might be wrong. However, you can cure that specific problem by entering:
chmod +x /home/pi/rpidatv/scripts/shutdown_script.sh
Let me know how that goes.
