August activity days - change of date - now 4th and 5th
Re: August activity days - change of date - now 4th and 5th
Post by g8gtz » Wed Aug 01, 2018 10:14 am
As well as trying to get as many stations on the air using their own gear on Long Mynd, there is an opportunity for us to operate on some of the other bands but it will be good to know in advance what gear to take up.
71MHz - Will take my simple set up (anyone got a beam we can borrow?)
146MHz - there will be gear on site
437MHz - there will be gear on site
23cms - without scheds probably will not take the gear.
13cms - without scheds will not take the gear.
9cms - without scheds will not take the gear.
5.6Ghz - yes
10GHz - be keen to try any long paths but without scheds will not take the gear.
24GHz - even more keen to try any long paths but without scheds will not take the gear (happy to have NB scheds).
76GHz - be keen to try any realistic paths (~20Kms) but without scheds will not take the gear.
Talkback via 144.750, mobile and various Zello channels
G8AGN
Post by G8AGN » Wed Aug 01, 2018 12:16 pm
do you have a locator for the Long Myndd site so I can check path visibility?
Barry, G8AGN
Post by g8gtz » Wed Aug 01, 2018 6:29 pm
Hi Barry
IO82NN60IQ - looks a direct line of sight path.
G8AGN
Post by G8AGN » Thu Aug 02, 2018 7:19 pm
Many thanks
Barry G8AGN
Post by M0DTS » Thu Aug 02, 2018 8:49 pm
I hope to be active on Sunday from IO94MJ, it's looking like everyone will be too far away but will give it a try anyhow ;-)
G7JTT
Post by G7JTT » Fri Aug 03, 2018 5:53 am
Sorry in Manchester for a family commitment so no radio 🙁
Post by G4EWJ » Fri Aug 03, 2018 3:20 pm
Barry G8AGN,
If you're going to be at Merryton Low, there's a good chance I'll be able to work you on 6cm from my home QTH in Birkenhead, IO83LI69JJ. I'll be around until 15:15.
Post by g0mjw » Fri Aug 03, 2018 8:29 pm
I am up on Winter Hill with 2m and 70cm and 23cm.
The path seems line of sight - probably good on 10GHz and 24 GHz if I had it with me. Its 119km long, bearing 11 degrees.
Here is the terrain in between - pretty flat
And here is the significant obstruction into the first Fresnel zone... IO83QE11 a local high spot.
G8AGN
Post by G8AGN » Sat Aug 04, 2018 9:13 am
I'll aim to be at Telephone Triangle, just south of Merryton Low IO93AD41WS from 1400BST and will have talkback on 144.750 25watts to a whip
5665 ATV only
Barry, G8AGN
M0DHP
Post by M0DHP » Sat Aug 04, 2018 9:47 am
I plan to be in Upper Colwall in the Malvern Hills (IO82TB) from 1000BST tomorrow.
437MHZ DATV
Talkback on 144.750MHz, mobile 07754 915272 and Zello
If I'm successful working Long Mynd from there, I may relocate later to Broadway Tower (IO92BA).
Ray M0DHP
