Stream User Code Changing...
G8DKC
Post by G8DKC » Wed Jun 06, 2018 12:56 pm
New Streamer, Probably teething troubles...
Worth looking at if you are not getting in, check the code after your call sign......
As in.... rtmp://rtmp.batc.org.uk/live/g8dkc-abcdef
GQ has changed about 3 times.
Keep up the good work...
Peter
Phil M0DNY
Re: Stream User Code Changing...
Post by Phil M0DNY » Wed Jun 06, 2018 4:05 pm
Hi Peter,
We're looking into this. Can you please tell me what browser you're using when accessing your Account Dashboard?
Phil M0DNY
G8DKC
Post by G8DKC » Tue Jun 12, 2018 9:16 pm
Hi Phil,
Sorry missed your post, have exchanged emails with Dave on this subject, and it looks like it was the odd use of IE11 when logging in. 100% Firefox with new streamer has solved the problem.
BTW streaming problems with Pi are probably due to Router failing for a few seconds and reconnecting, maybe a line fault etc...
Went down again this evening, just for a moment, when on forum...
Also use inverters, solar power, batteries, generator etc. the joys of living in the sticks....
Fridge on a totally different inverter / battery circuit, that has eliminated the power dip on start-up.
Maybe isolate the Pi on its own UPS...
Will post when I find the gremlin.
Peter
G8DKC
Post by G8DKC » Wed Jun 13, 2018 4:24 pm
Swapped out Router today to see if this cures intermittent dropouts, BT line clean at the moment...
Peter
Return to “Streaming”
