Shutdown button works well....
Post by radiogareth » Thu Mar 01, 2018 2:13 pm
...but could we have a 'BOOT' function in some way? At the moment, I need to pull the plug as its still in 'scattered all over the bench' trial assembly mode. Could the existing button be made into a toggle function? 'Wake up on port change' in microcontroller speak.
No harm in asking.....
Tnx
Re: Shutdown button works well....
Post by G8GKQ » Thu Mar 01, 2018 4:08 pm
Hi Gareth
If you have a touchscreen connected, the "Reboot" button on screen 2 should shutdown and restart for you. The Reboot option on the Shutdown page of the console menu has the same effect.
Beyond that, all I can suggest is a heavy-duty push-to-break button in the power line as once the RPi is shutdown it's a brick.
aerostar
Post by aerostar » Thu Mar 01, 2018 4:55 pm
Have a look at this thread - there are 2 pads marked RUN on PI3 and these could do what you want.
https://www.raspberrypi.org/forums/view ... 1&t=147361
M1ASR
Post by M1ASR » Fri Mar 02, 2018 3:10 am
Yes, just fit a momentary switch to the “run” pads on the rpi3.
I do this with all my rpi projects.
Graham M1ASR
Post by radiogareth » Fri Mar 02, 2018 10:02 am
Excellent, just what I was hoping for :-)
Thanks.
Post by G8GKQ » Fri Mar 02, 2018 4:47 pm
I learn something every day!
