Off set test card?
G4uvz
Off set test card?
Post by G4uvz » Tue Dec 12, 2017 4:05 pm
For some reason one of the cycle of test cards seems to have moved sideways...it's the same on the rpi screen and the off air signal?
Adrian
Re: Off set test card?
Post by G8GKQ » Tue Dec 12, 2017 4:17 pm
Hi Adrian
Well spotted! Yes, I erroneously saved the test cards that I am using for the CardMPEG2 mode in the folder for the carousel of cards. They are a larger image size (720x576 vs 640x480) so overflow the top and right of the screen.
I'll correct the problem with the next software update.
PS - There is one advantage. If you've ever used the CardMPEG2 mode with the caption enabled, you'll find that one of the cards has your callsign on it.
G4uvz
Post by G4uvz » Tue Dec 12, 2017 4:31 pm
Thanks Dave! Ken BVK can just about rx me on 437 SR1000 ..which is on H264..he asked if I could send on MPeg2 ..but not sure how to do this ...if indeed I can!
Adrian
Post by G8GKQ » Tue Dec 12, 2017 6:58 pm
