PAs for Portsdown
Re: PAs for Portsdown
Post by radiogareth » Sun Nov 19, 2017 7:54 pm
Wondering what people are using as PA's on 70MHz (low band Pye sets at much reduced power maybe), 144 and 1250?
M0SKM
Post by M0SKM » Sun Nov 19, 2017 8:45 pm
I'm using the HF amplifier kit from Minikits; works well on 50/70MHz. You'd have to adjust levels for good linearity.
http://www.minikits.com.au/electronic-k ... -Amplifier
Steve
Post by g0mjw » Sun Nov 19, 2017 9:15 pm
I have a linear broadband amplifier that will do up to a watt and a 500W I0JXX pallet amplifier that when correctly biased can do up to about 25W. I am planning to use just the 1W initially which will be 10W ERP.
Post by radiogareth » Mon Nov 20, 2017 5:01 pm
Interesting. These http://www.ebay.co.uk/itm/170W-FM-VHF-8 ... SwQaJXSBqU go like a rocket and other than needing 28 volts for max beans may be useful. As a guide, It will deliver 110W out on 4M with 2.5 watt drive. So throttled right back we might see 20 watts?? I'm NOT an RF expert in any shape or form, but a happy experimenter.....
It also does 6M and 2 M although the input matching may need tweaking.
G4uvz
Post by G4uvz » Sun Dec 10, 2017 8:50 pm
OK I have 10mW coming out of my Portsdown ! I understand that most use a Mitsubishi module for 2 and 70cms I have a wideband ' linear; amp which is delivering around 200mW
So my question which ones do I need and where do you get them?
Adrian
Post by g0mjw » Sun Dec 10, 2017 8:58 pm
Minikits are a good suppler http://www.minikits.com.au/ specifically http://www.minikits.com.au/electronic-k ... high-power
RA60H3847M1 RF Module 60W 378-470MHz for 70cm
RA18H1213G RF Module 18W 1240-1300MHz for 23cm
For 2m have a look at M0DTS web page. http://www.m0dts.co.uk/index.php?tag=146MHz
Roberto Zech DG0VE https://www.dg0ve.de/en/ or Bert Modermann PE1RKI http://www.pe1rki.com/ for ready made units.
G4uvz
Post by G4uvz » Sun Dec 10, 2017 10:28 pm
Thanks for the info ..but not sure that it is what I want! Really want to homebrew and I thought that I could get a 60-80 watt module and under run ? The minikkits only seem to do an 8 watt 2 M unit?
I was totally confused with the M0DTS site!
M0SKM
Post by M0SKM » Sun Dec 10, 2017 11:09 pm
Try this link for the high power RF amplifiers. Select the appropriate board for the band; and the choice of Mitsubishi modules to match will be revealed.
Also this link on the M0DTS site for a 2 metre PA.
http://www.m0dts.co.uk/index.php?item=144
Steve
Post by g8gtz » Mon Dec 11, 2017 9:05 am
https://wiki.batc.tv/146_MHz_amplifiers
Has more detail on the M0DTS PA (CQ-TV 247 and 249) and also the Mitsubishi brick amplifier which several people use (including myself) - module from Anglia components and PCB from Sam G4DDK.
73 Noel
G4FRE
Post by G4FRE » Mon Dec 11, 2017 12:47 pm
The last link is broken (error 404) , the gm3sek 60w circuit is at
http://www.ifwtech.co.uk/g3sek/vhfdx/gm ... -board.jpg (.jpg missing from the end of link)
g4fre
