the Serit NIM FTS4334 is very sensitive to any noise, jitter, distorsion.. in the signal. ( more than a Sharp or Eardatek)
I have worked the last/next version of Minitioune v0.7c to allow a better sync to low SR and also direct receiving of 70cm or 146 MHz signal.
DatvExpress gives a very good result down to 146 Mhz and low SR (70 kS/s) concerning only the modulation:
- the only big problem with the use of DATVexpress is the very bad TS that is produced ( bad synchro, bad PCR, bad audio PTS, bad video PTS..),
but the analog signal is fantastic!
So, I only want to compare the DATV express analog signal and the PLUTO analog signal using the Serit NIM:
Using the DATVexpress, at 146MHz, or 437 MHz or 1255MHz , all SR tested between 70 kS/s and 4000 kS/s, MER is always betwwen 33 and 36 dB and look at the constellations, they show a signal free of noise or artefact. Superbe!
- DatvExpress_437MHz_SR075_8PSK.jpg (411.88 KiB) Viewed 13314 times
Using the PLUTO:
- PLUTO_437MHz_SR500_8PSK.jpg (433.81 KiB) Viewed 13314 times
I can get a better synchro lock changing the Nyquist filter reference inside the demodulator, but the constellatiion/MER stay low quality:
- PLUTO_437MHz_SR500_8PSK_Nyqyst_Ref_twist.jpg (411.27 KiB) Viewed 13314 times
So I think that there is something to improve in the PLUTO signal. ( each "cloud" is made of 4 little "clouds" )
Concerning Minitioune V0.7c (coming soon), result are better now than using a Sharp and direct reception of 437MHz or 146 MHz ( with preamp) now
has not less sensitivity than the use of a converter.
Jean-Pierre F6DZP
