Newbee question
G4WIM
Newbee question
Post by G4WIM » Tue Aug 01, 2017 10:01 am
Just getting set up to stream GB3FT using a RPI3, easycap and Portsdown - looks like I need to register for a stream.
Been poking around in the wiki and not found anything which helps me - any chance of quick pointer ?
73 Tim
M0SKM
Re: Newbee question
Post by M0SKM » Tue Aug 01, 2017 2:50 pm
Hello Tim,
Here is the link. https://batc.org.uk/members/streams.php
Only works if you're logged in.
Steve
G4WIM
Re: Newbee question
Post by G4WIM » Tue Aug 01, 2017 3:35 pm
HI Steve,
Thanks for the link - sadly I had already discovered that page and another with a pdf showing how to set up the url etc - neither of which I found useful when trying to get the Portsdown to stream to the BATC.TV streamer.
As I see it there's two parts needed.
1. How to configure the Portsdown
2. How to set up a streaming account and associate it with #1 above.
I'm sure the info must be 'out there' - just can't find it....
73 Tim
Re: Newbee question
Post by g8gtz » Tue Aug 01, 2017 4:38 pm
Hi Tim,
I can help you with 2.
As admin, I need to associate a GB3FT steam with your BATC account (you only get a member's stream as standard) and will send you the URL ans stream name by PM. There's a wiki page here https://wiki.batc.tv/BATC.TV_video_streaming_service which doesn't help you much as the Portsdown section is not written yet...
Once you have the details, I'm pretty sure the Portsdown is self explanatory under the output menus.
G4WIM
Re: Newbee question
Post by G4WIM » Tue Aug 01, 2017 5:09 pm
Hi Noel,
once again thanks in advance for your help - hopefully I can get the streaming working on a RPI3 + easycap dongle + comag sl30/12 running Portsdown code ready for a co-operative local to provide streaming of GB3FT.
Initially I'll be testing it from here.
Looks as though a few of the locals are getting geared up to 'go digital and later tonight I'll be testing out the 146.5MHz RBW rx with Brian G4EWJ ready for deployment.
73 Tim
Re: Newbee question
Post by g0mjw » Tue Aug 01, 2017 5:17 pm
Hi Tim,
The Portsdown setup requires console mode - you just look on the streamer to find your address and copy it to the Portsdown. I will try to post a picture.
First screen missing as forum only allows 3 - anyway its pretty obvious
G4WIM
Re: Newbee question
Post by G4WIM » Tue Aug 01, 2017 7:33 pm
Thanks, Mike
All working nicely now :-)
73 Tim
Return to “Streaming”
