EasyCAP for RaspberryPI
Re: EasyCAP for RaspberryPI
Dave - Thanks for the a.sh. Working now. I think that it was the sound causing me issues.
I'm working on getting it into the main build.
Hi dave, here are the results :
[ 223.627872] usb 1-1.2: new high-speed USB device number 6 using dwc_otg
[ 223.728817] usb 1-1.2: New USB device found, idVendor=1c88, idProduct=0007
[ 223.728839] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 223.728852] usb 1-1.2: Product: SM-USB 007
[ 223.728865] usb 1-1.2: Manufacturer: Somagic, Inc.
[ 223.728877] usb 1-1.2: SerialNumber: SMBL007
Waiting for my new easycap ordered which will arrive in few days ...
Hi everybody,
I've just received my new Easycap key but it does not works
lsusb :
Bus 001 Device 004: ID 0d8c:000e C-Media Electronics, Inc. Audio Adapter (Planet UP-100, Genius G-Talk)
Dmesg :
[ 65.589804] usb 1-1.4: new high-speed USB device number 6 using dwc_otg
[ 65.691307] usb 1-1.4: New USB device found, idVendor=534d, idProduct=0021
[ 65.691330] usb 1-1.4: New USB device strings: Mfr=1, Product=0, SerialNumber=0
[ 65.691344] usb 1-1.4: Manufacturer: MACROSIL
[ 65.692394] uvcvideo: Found UVC 1.00 device <unnamed> (534d:0021)
[ 65.692893] uvcvideo: UVC non compliance - GET_DEF(PROBE) not supported. Enabling workaround.
[ 2.466299] usb 1-1.4: Manufacturer: MACROSIL
[ 2.871764] input: CM109 USB driver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.3/input/input0
[ 2.872157] usbcore: registered new interface driver cm109
[ 2.987910] usbcore: registered new interface driver snd-usb-audio
[ 3.304937] usbcore: registered new interface driver brcmfmac
[ 3.321967] usbcore: registered new interface driver uvcvideo
In the menu item I've choosen /dev/video1 (also try with 0) the TX don't want go on ...
Please Help.
lsusb :
Dmesg :
Please Help.
Where I got it : https://www.amazon.fr/gp/product/B00572 ... UTF8&psc=1F5SWB Dimitri wrote:Hi everybody,
I've just received my new Easycap key but it does not works![]()
lsusb :
Dmesg :
Please Help.
Hi guys,
I have succeed according the idea of G0EID with his post Sat Oct 29, 2016 6:06 pm !
Now it works, but is it normal that the easycap is encoded in H264 ? Not in MPEG2 ?
73's to all.
Dimitri.
73's to all.
Dimitri.
It works for me now with :
in /etc/udev/rules.d/ezcap.rules :
SUBSYSTEM=="video4linux", ATTRS{idVendor}=="534d", ATTRS{idProduct}=="00212", MODE:="0660", SYMLINK+="ezcap0"
accordign to my key, I think it should works with other usb cap
Hi tried the above but still not working with my EASYCAP details below
Bought from http://www.ebay.co.uk/itm/261591581731? ... EBIDX%3AIT
my info
pi@raspberrypi:~ $
[ 3.579423] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[ 3.681516] usb 1-1.4: New USB device found, idVendor=534d, idProduct=0021
[ 3.681542] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber =0
[ 3.681555] usb 1-1.4: Product: AV TO USB2.0
[ 3.681568] usb 1-1.4: Manufacturer: MACROSIL
[ 4.224601] usbcore: registered new interface driver snd-usb-audio
[ 4.301926] usbcore: registered new interface driver brcmfmac
[ 4.315768] usbcore: registered new interface driver uvcvideo
pi@raspberrypi:/etc/udev/rules.d $ sudo v4l2-ctl -d 0 --all
Driver Info (not using libv4l2):
Driver name : uvcvideo
Card type : AV TO USB2.0
Bus info : usb-3f980000.usb-1.4
Driver version: 4.4.34
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 1: ok)
Format Video Capture:
Width/Height : 720/480
Pixel Format : 'YUYV'
Field : None
Bytes per Line: 1440
Size Image : 691200
Colorspace : Unknown (00000000)
Flags :
Crop Capability Video Capture:
Bounds : Left 0, Top 0, Width 720, Height 480
Default : Left 0, Top 0, Width 720, Height 480
Pixel Aspect: 1/1
Selection: crop_default, Left 0, Top 0, Width 720, Height 480
Selection: crop_bounds, Left 0, Top 0, Width 720, Height 480
Streaming Parameters Video Capture:
Capabilities : timeperframe
Frames per second: 30.000 (30/1)
Read buffers : 0
brightness (int) : min=0 max=255 step=1 default=-8193 value=32
contrast (int) : min=0 max=255 step=1 default=57343 value=128
saturation (int) : min=0 max=255 step=1 default=57343 value=128
hue (int) : min=0 max=127 step=1 default=-8193 value=0
gamma (int) : min=0 max=50 step=1 default=57343 value=0
Mark G0LGJ
my info
pi@raspberrypi:~ $
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Video Capture
Streaming
Extended Pix Format
Priority: 2
Field : None
Size Image : 691200
Flags :
Pixel Aspect: 1/1
Read buffers : 0
Mark G0LGJ
Hello dave, it should work because you've got the same EASYCAP
Have you insert the line according to the idea of G0EID with his post Sat Oct 29, 2016 6:06 pm ?
I did it and it works for me ...
73's Dimitri.
73's Dimitri.
Hi Dimitri,F5SWB Dimitri wrote:It works for me now with :
I think there is a typo in your example above, please double check and let us know which line in the rules file works for you?
Hi Mark,
Your hardware ID's are reported as:
So, please try the line below, reboot, and let us know if it works for you?
SUBSYSTEM=="video4linux", ATTRS{idVendor}=="534d", ATTRS{idProduct}=="0021", MODE:="0660", SYMLINK+="ezcap0"
Select the ANALOGCAM input source and use /dev/ezcap0 as the device name.
Hi I have that line already , I am using this to stream to BATC maybe this is the problem as it is in wrong mode ? mpg2 ?
Streamer sees I am "Transmitting" but no video.
Mark G0LGJ
Mark G0LGJ
