I'm not sure that I understand you. If you can see the menu on the LCD, the Pi must have booted up.
In normal operation, you never see the files loading.
If there is a menu on on the LCD, and you log in using a computer over the network, what do you see on the computer screen?
If you end up at the Linux command prompt, and don't know where you are, enter
/home/pi/rpidatv/scripts/menu.sh menuDave
