ATV activity weekend - August 13th and 14th 2016
Post by g8gtz » Thu Aug 04, 2016 4:13 pm
Due to family commitments I will only be active on the Saturday.
Currently thinking about going to Dunstable Downs, which has excellent take off to the North and North West - https://wiki.batc.tv/Dunstable_Downs_Bedfordshire - or somewhere in the Oxford area but not yet decided.
Plan would be to take all bands from 146MHz - 10 GHz.
73 Noel - G8GTZ
Re: ATV activity weekend - August 13th and 14th 2016
Post by G8GKQ » Tue Aug 09, 2016 7:32 am
Regrettably, I will not be active this coming activity weekend as we have visitors from the USA staying with us. However, I look forward to seeing details of others' plans and activity posted here.
Post by G4EWJ » Tue Aug 09, 2016 10:42 am
G3NWR will be at Anchor, Shropshire or Merryton Low, Staffordshire.
g8vpg
Post by g8vpg » Tue Aug 09, 2016 5:07 pm
I plan to be out portable on Saturday, with 146.5 & 437MHz, any symbol rate. The current plan is for a return to the Blorenge mountain.
73 Shaun.
Post by g8gtz » Tue Aug 09, 2016 7:10 pm
I'm now confirmed for Dunstable Downs but with an early start (9am ready to go) and probably leaving site by 2pm - the tropo forecast is looking good for Saturday AM so it may pay to make an early start!
There should be a path to Bloringe and Brian's potential sites in the Peak District or Shropshire on 146MHz and also to Rob on the NYM. I also plan to spend some time working the locals in the Luton area so will need to plan things a bit.
Ideally I would only take 146 and 437 but can also take 23cms if it means I will work others in the area but no 10 GHz this time.
Talk back will be 144.750, mobile phone and http://www.dxspot.tv. Don't forget the low bandwidth version of the chat if you are out mobile but you will need to first log in to the main site first with your device (to pick up authentication cookies) and then go to https://philcrump.co.uk/dxchat/?room=1.
73 Noel - G8GTZ
Post by G4EWJ » Thu Aug 11, 2016 9:17 am
G3NWR will be at Merryton Low, Staffordshire with a possible quick stop south of Buxton, Derbyshire on the way. Saturday only, noon onwards.
We'll have tx / rx on 2m, 23cm, 3cm and rx on 70cm.
M0SKM
Post by M0SKM » Thu Aug 11, 2016 5:34 pm
Don G0WFT, Arthur G4CPE and Steve M0SKM will be active both days from our respective QTH's.
Don (IO91RW) on 146.5/437 and 23cm analogue.
Arthur (IO91SW) on 146.5/437/23cm and 13cm.
Steve (IO91RV) on 146.5/437/23cm analogue.
We will be using DXSpot.TV
Have a good weekend all.
Steve
g8vpg
Post by g8vpg » Fri Aug 12, 2016 10:35 am
Brian G6AUR & myself will be going to the Blorenge Mountain, near Abergavenny, on the Saturday only. We hope to be there and set up by 10.00am. We will have 146.5 & 437MHz, any symbol rate.
73 Shaun G8VPG.
G8DKC
Post by G8DKC » Fri Aug 12, 2016 11:01 am
I'm going to a modest location on Saturday, a very open 132m surrounded by arable crops and corn stubble,
52.664655° -1.546293° near the top of the M42 a mile NNE of Twycross Zoo off the A444.
146.5 Rx and 437 Tx, 23cms digital Rx.
Hope to get signal to and from Brian for a start, but first trip out...
Peter
Post by M0DTS » Fri Aug 12, 2016 3:58 pm
I'll try to get out /P early tomorrow, probably 10-3pm.
Bands: 2m/23/13/3cm Analogue and Digital.
dxspot, 07999796421 or 144.750 talkback.
That tropo Noel was talking about has dried up now though looking at the maps.
