Garage Clearence. Version 4
G8ADM
Post by G8ADM » Mon Oct 05, 2015 5:04 pm
No charge for any of that below. You collect.
Or I may be able to deliver within about 40 miles of N W London.
Microwave
4 x L Band, 0.95 - 1.875 GHz input power transmit up converter, Output 5.85 - 6.725 GHz, 1.6 W. Digital capable.
Switchers
1 x LNB Rack Mounted Switch, 1U, 16 in to 1 out, F connectors.
1 x Video and Audio switch. 12 in 1 out. 2U Rack Mount.
Satellite Receivers and decoders
1 x Advent AVR3950 Analogue Satellite Receiver. 1U Rack mount.
1 x Harmonic, HD/SI in to ASI out converter. 1U Rack mount.
1 x Live Tools Digital Satellite Receiver. 1U Rack mount.
1 x Novella Satellite Beacon Tracker/Receiver.
2 x Philips DVS3824/1 Digital Satellite receiver, 1U Rack mount.
1 x Tandberd TT1200 MPG II Digital Receiver 1U rack mount.
2 x Tandberd TT1220 MPG II Digital Receiver 1U rack mount.
1 x as above, parts missing.
1 x Tandberd TT1220 Transport stream decoder. 1U rack mount.
2 x Tandberg TT612 ASI Transport stream decoder. 1U rack mount.
1 x Teirnan TDR7 Digital Satellite Receiver 2U Rack mount.
7 x Tandberg Alteia Digital Satellite Receiver QPSK, 1U Rack mount.
5 x Tandberg Alteia Satellite Decoder, Transport stream in. 1U Rack mount.
1 x Tandberg QPSK to QAM converter. 1U Rack Mount.
1 x Standard MT900 Analogue satellite receiver. 1U Rack mount.
1 x Standard Communications Digital Receiver similar to the Alteia. 1 U rack mount.
1 x as above, tuner board missing.
1 x Standard Communications QPSK Satellite receiver, SDR400, 1U rack mount.
1 x Standard Communications Analogue Satellite Receiver MT900, 1U rack mount.
1 x Unity 4000 Digital Satelite Receiver. 1U Rack mount.
Dish Controllers
1 x Research Concepts RC1000 singal axis dish controller. No motors or sensors. 2U Rack mount.
1 x Research Concepts RC2000 dual axis dish controller. No motors or sensors. 2U Rack mount.
Modulators etc.
1 x Tandberg DVBS Modulator QPSK. 1U Rack mount.
1 x 13cm analogue transmitter, 10W output. Small box, home made.
Video Equipment
Cox Component Vision Mixer T8C, and rack mount unit, interconnecting cables missing, simple to make!
Cox Component Colour Corrector 660. Control panel and rack mount unit.
Questech PAL Comb Decoder2009. 2U Rack mount.
Tektronix Oscilloscope HP465. Solid sate plus CRT. Faulty timebase driver.
There's more! What do you need?
Dave. G8ADM. E&OE
Email: g8adm@gb3bh.com
m0aeu
Re: Garage Clearence. Version 3
Post by m0aeu » Thu Dec 10, 2015 6:44 pm
Hello Dave...
Have you got rid of the FT225 yet?
I might be interested!
Is there anything in your garage clearance you would recommend for a novice TV enthusiast that has yet to really get going? :-D
Cheers
Frank, M0AEU
G8ADM
Post by G8ADM » Tue Dec 15, 2015 1:53 pm
Hi Frank
Yes sorry, the FT225 is gone...
And there's not much to help you get started.
G4DHO
Re: Garage Clearence. Version 4
Post by G4DHO » Sun Jan 24, 2016 1:16 pm
Good afternoon Dave
I am looking for an analogue sat rx I not sure which rxs on the forum would suit my needs best .the Advent 3950 or the
MT 900 if either or both are available I would be able to come down from Stoke to collect and decide then.naturally at your convenience although Wednesdays are probably the best for me . if you have already parted with these articles then just let me know. king regards to you and your family
Albert G4DHO
