10ghz. ATV
G4HTZ
10ghz. ATV
Post by G4HTZ » Fri Nov 20, 2015 2:42 pm
I am currently getting together the equipment for a 10ghz analogue station.
Already have a 11w DL2AM amplifier and DB6NT tx on 10315mhz should be here next week.
Sky dish with a GW4DGU feedhorn to feed it
RX side is with a modified 9ghz LO LNB.
Please let me know if your active in the south east or east Anglia...or anywhere else for that matter ...would be good to know who has equipment for 10ghz.
Qth here is only 3m asl on Essex coast 4miles east of Southend , but dish will be mounted about 45ft on top of a scam mast .
So can easily be removed for portable work from a Essex high spot ..yes we do have some about 120m high !!
Cheers
Steve
Steve G3GHZ
Canewdon Essex JO01IO
5665 ATV FM
Re: 10ghz. ATV
Post by g8gtz » Fri Nov 20, 2015 4:27 pm
Hi Steve,
I do have 10 GHz rx which works and maybe tx but not sure if it works!
We may be able to work from Walbury to Essex high spots and I'm planning to go out during the ATV activity weekend Dec 12th and 13th.
g3uvr
Re: 10ghz. ATV
Post by g3uvr » Fri Nov 20, 2015 10:50 pm
Hi Folks.
I have 10ghz equipment for ATV and WBFM. Bit out of range from the southeast but you never know.
1w to Andrews dish Analog only. At the moment from home only as portable RX failure hence my want request for Sharp tuner.
73 de Denis G3UVR
G4HTZ
Re: 10ghz. ATV
Post by G4HTZ » Mon Nov 23, 2015 8:39 am
Unfortunately away in Scotland the activity weekend
Steve G3GHZ
5665 ATV FM
