New Streamer, Probably teething troubles...
Worth looking at if you are not getting in, check the code after your call sign......
As in.... rtmp://rtmp.batc.org.uk/live/g8dkc-abcdef
GQ has changed about 3 times.
Keep up the good work...
Peter
Stream User Code Changing...
Phil M0DNY
Re: Stream User Code Changing...
Hi Peter,
We're looking into this. Can you please tell me what browser you're using when accessing your Account Dashboard?
Phil M0DNY
Phil M0DNY
Hi Phil,
Sorry missed your post, have exchanged emails with Dave on this subject, and it looks like it was the odd use of IE11 when logging in. 100% Firefox with new streamer has solved the problem.
BTW streaming problems with Pi are probably due to Router failing for a few seconds and reconnecting, maybe a line fault etc...
Went down again this evening, just for a moment, when on forum...
Also use inverters, solar power, batteries, generator etc. the joys of living in the sticks....
Fridge on a totally different inverter / battery circuit, that has eliminated the power dip on start-up.
Maybe isolate the Pi on its own UPS...
Will post when I find the gremlin.
Peter
Peter
Swapped out Router today to see if this cures intermittent dropouts, BT line clean at the moment...
Peter
Peter
