G4BAO 45 Watt 23cms PA kits question
Basil
Post by Basil » Sat Nov 28, 2015 2:58 pm
These have just become available again, please see the Downloads page at http://www.g4bao.com/ for info. My question is whether this is a good buy for getting started on 23cms digital ATV? My post code is SY13 2BT, locator IO82qv. I would be looking to get into the GB3UD repeater at Mow Cop. If the PA is technically suitable should I also buy the driver board kit as well? I would need to buy a digital TX as I currently have no 23cms gear at all. Thanks.
Best regards,
Basil
Re: G4BAO 45 Watt 23cms PA kits question
Post by Basil » Sun Nov 29, 2015 6:09 pm
Anyone, these are going fast, I need to act soon, thanks.
Best regards,
Post by g8gtz » Sun Nov 29, 2015 6:37 pm
I'm not sure if these will enable you to get in to UD as that depends on so many other factors but I do know John and his kits are very good. Bear in mind that you will need to back it off by probably 50% to get the required shoulders on your DATV signal.
Hope this helps
Noel G8GTZ
