Picotuner regulator heatsink requirements
G6AHK
Post by G6AHK » Fri Sep 27, 2024 9:07 am
The Picotuner PCB has heatsink pads below voltage regulators U2, U4, U5 and U6. Is it recommended to use thermal grease below the devices, or to attempt to solder them to the pads - or are they likely to remain cool enough without? (I soldered U1 as per the online instructions.)
Many thanks to Mike G0MJW and all involved with this project!
Chris
Re: Picotuner regulator heatsink requirements
Post by g0mjw » Fri Sep 27, 2024 1:09 pm
These devices must be soldered to the pads. That's how they work.
G6AHK
Post by G6AHK » Fri Sep 27, 2024 3:54 pm
Thanks Mike.
I've now found reference to that in the online TI datasheet on p.24, so I guess it's (another!) case of RTFM.
Thanks,
Chris
Post by g0mjw » Fri Sep 27, 2024 6:11 pm
Good. Sorry for the short reply as I was in a meeting. The devices are designed to be soldered to the PCB and the PCB is used as a heatsink. In many cases it is also the ground connection.
