Shutdown button works well....
...but could we have a 'BOOT' function in some way? At the moment, I need to pull the plug as its still in 'scattered all over the bench' trial assembly mode. Could the existing button be made into a toggle function? 'Wake up on port change' in microcontroller speak.
No harm in asking.....
Tnx
Tnx
Re: Shutdown button works well....
Hi Gareth
If you have a touchscreen connected, the "Reboot" button on screen 2 should shutdown and restart for you. The Reboot option on the Shutdown page of the console menu has the same effect.
Beyond that, all I can suggest is a heavy-duty push-to-break button in the power line as once the RPi is shutdown it's a brick.
Have a look at this thread - there are 2 pads marked RUN on PI3 and these could do what you want.
https://www.raspberrypi.org/forums/view ... 1&t=147361
Yes, just fit a momentary switch to the “run” pads on the rpi3.
I do this with all my rpi projects.
Graham M1ASR
Graham M1ASR
Excellent, just what I was hoping for
Thanks.
Thanks.
I learn something every day!
