little output power (no modulation?)
Hi everybody,
I am currently upgrading my Portsdown to the 2020 version with the LimeMini I had here collecting dust. So when taking a brandnew Buster installation, a powered USB hub and upgrading the Lime to FW 1.30 and then the DVB FW, I end up with a very low (-45dBm) unmodulated output sitting on a noise pedestal.. Any ideas what I am missing?
73s Achim
73s Achim
- 20200611_095128_resized.jpg (53.46 KiB) Viewed 9460 times
- 20200611_095116_resized.jpg (51.23 KiB) Viewed 9460 times
- 20200611_095106.jpg (40.35 KiB) Viewed 9460 times
- 20200611_095047_resized.jpg (49.82 KiB) Viewed 9460 times
- 20200611_095029_resized.jpg (63.97 KiB) Viewed 9460 times
Re: little output power (no modulation?)
And the spectrum as last image.. the signal in the middle is indeed unmodulated.
- 20200611_095323_resized.jpg (74.49 KiB) Viewed 9459 times
Hi Achim
Try setting the Audio to "Auto" rather than "Bleeps". Not sure "bleeps" work with H264.
Or try Modulation, Carrier as a starting point.
Dave,
sadly no change. Neither with Audio nor Carrier (output power even decreased but shape did not change). Probably something obvious.
Just one observation, you said you updated the Lime to the DVB firmware, I thought there was a special setting for that in the ‘Output to’ button.
Colin, you saved me a great deal of more grey hairs! That was it, thank you very much for spotting this noob error. RTFM..
Glad to help...
