Firmware update fails
g6hfs
Post by g6hfs » Mon Jan 19, 2026 4:33 pm
Help info on why my Winterhill fails to update, it stays on older installed version after reboot.
Re: Firmware update fails
Post by G4EWJ » Tue Jan 20, 2026 12:06 am
I can see a comment on github '202512190 Amend the sources.list to legacy'
I think this must be some housekeeping relating to where the RPi packages come from, as they move them around sometimes. That must have triggered a change to the 'latest version' file.
The ZR6TG client version of WH is on github, which I believe is not installable at the moment. There has only ever been one version of my original WH on github. I'm not sure what the development install does - probably the same as the main install.
g6hfs
Post by g6hfs » Tue Jan 20, 2026 11:00 am
Thanks Brian,
Presumably just wait to see if a fix is available.
