Winterhill ZR6TG install not working
DL5BCA
Post by DL5BCA » Fri Jan 02, 2026 1:44 pm
Yesterday my SD card in Winterhill broke.
So today I bought a new one and wanted to install the Winterhill system from TOM ZR6TG.
Of course, I installed the buster image from April 4, 2022, beforehand.
Unfortunately, it's not working. It's not finding everything during the download.
Does anyone have any advice?
Here's the text I'm getting:
login as: pi
pi@192.168.178.74's password:
Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Mon Apr 4 15:04:23 2022
SSH is enabled and the default password for the 'pi' user has not been changed.
This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
pi@raspberrypi:~ $ wget https://raw.githubusercontent.com/tomvd ... terhill.sh
--2026-01-02 13:37:53-- https://raw.githubusercontent.com/tomvd ... terhill.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.111.133, 185.199.108.133, 185.199.109.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.111.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 8816 (8.6K) [text/plain]
Saving to: ‘install_winterhill.sh’
install_winterhill. 100%[===================>] 8.61K --.-KB/s in 0.001s
2026-01-02 13:37:53 (11.6 MB/s) - ‘install_winterhill.sh’ saved [8816/8816]
pi@raspberrypi:~ $ chmod +x install_winterhill.sh
pi@raspberrypi:~ $ ./install_winterhill.sh -d
----- Installing development version of WinterHill-----
----- Disabling the raspberry ssh password warning -----
---- Loading required packages -----
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
cmake-data librhash0 libutempter0 libuv1 libxdo3 xbitmaps
Suggested packages:
cmake-doc ninja-build xfonts-cyrillic
The following NEW packages will be installed:
cmake cmake-data librhash0 libutempter0 libuv1 libxdo3
raspberrypi-kernel-headers xbitmaps xdotool xterm
0 upgraded, 10 newly installed, 0 to remove and 0 not upgraded.
Need to get 32.9 MB of archives.
After this operation, 205 MB of additional disk space will be used.
Get:1 http://archive.raspberrypi.org/debian buster/main armhf cmake-data all 3.16.3-3~bpo10+1 [1,628 kB]
Get:2 http://archive.raspberrypi.org/debian buster/main armhf cmake armhf 3.16.3-3~bpo10+1 [2,500 kB]
Err:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf librhash0 armhf 1.3.8-1
404 Not Found [IP: 93.93.128.193 80]
Get:4 http://archive.raspberrypi.org/debian buster/main armhf raspberrypi-kernel-headers armhf 1:1.20220308~buster-1 [27.7 MB]
Err:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf libuv1 armhf 1.24.1-1+deb10u1
Err:6 http://raspbian.raspberrypi.org/raspbian buster/main armhf libutempter0 armhf 1.1.6-3
Get:7 http://mirror.netzwerge.de/raspbian/raspbian buster/main armhf libxdo3 armhf 1:3.20160805.1-4 [30.2 kB]
Err:8 http://raspbian.raspberrypi.org/raspbian buster/main armhf xbitmaps all 1.1.1-2
Get:9 http://mirror.netzwerge.de/raspbian/raspbian buster/main armhf xdotool armhf 1:3.20160805.1-4 [50.6 kB]
Err:10 http://raspbian.raspberrypi.org/raspbian buster/main armhf xterm armhf 344-1+deb10u2
Fetched 31.9 MB in 6s (5,689 kB/s)
E: Failed to fetch http://raspbian.raspberrypi.org/raspbia ... _armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbia ... -2_all.deb 404 Not Found [IP: 93.93.128.193 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
---- Put the Desktop Toolbar at the bottom of the screen -----
sed: can't read panel: No such file or directory
---- Increasing gpu memory in /boot/config.txt -----
---- Set force_turbo for constant spi speed -----
---- Set the spi ports correctly -----
---- Setting Framebuffer to 32 bit depth -----
---- Setting GUI to start with or without HDMI display -----
---- Download & Install Dependencies for WinterHill Software ------
Cloning into 'libwebsockets'...
remote: Enumerating objects: 60370, done.
remote: Counting objects: 100% (1346/1346), done.
remote: Compressing objects: 100% (540/540), done.
remote: Total 60370 (delta 1178), reused 868 (delta 804), pack-reused 59024 (from 2)
Receiving objects: 100% (60370/60370), 55.39 MiB | 12.28 MiB/s, done.
Resolving deltas: 100% (45823/45823), done.
Note: checking out '2445793d15af39fac9ce527bb28ffd42a974bf4f'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
git checkout -b <new-branch-name>
HEAD is now at 2445793d windows: client connect: use sockaddr size
./install_winterhill.sh: line 105: cmake: command not found
make: *** No targets specified and no makefile found. Stop.
make: *** No rule to make target 'install'. Stop.
---- Download the WinterHill Software -----
--2026-01-02 13:38:42-- https://github.com/tomvdb/winterhill/archive/main.zip
Resolving github.com (github.com)... 140.82.121.3
Connecting to github.com (github.com)|140.82.121.3|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://codeload.github.com/tomvdb/wint ... heads/main [following]
--2026-01-02 13:38:43-- https://codeload.github.com/tomvdb/wint ... heads/main
Resolving codeload.github.com (codeload.github.com)... 140.82.121.10
Connecting to codeload.github.com (codeload.github.com)|140.82.121.10|:443... connected.
Length: unspecified [application/zip]
Saving to: ‘main.zip’
main.zip [ <=> ] 1.78M 7.02MB/s in 0.3s
2026-01-02 13:38:43 (7.02 MB/s) - ‘main.zip’ saved [1866370]
Archive: main.zip
9ff092daa1620d7c0db8aae9c8e409725cba3cbf
creating: winterhill-main/
inflating: winterhill-main/.gitignore
creating: winterhill-main/PIC-3v20/
inflating: winterhill-main/PIC-3v20/PIC.svg
inflating: winterhill-main/PIC-3v20/whpicprog-3v20.sh
inflating: winterhill-main/README.md
creating: winterhill-main/RPi-3v20/
inflating: winterhill-main/RPi-3v20/whdriver-insert-3v20.sh
inflating: winterhill-main/RPi-3v20/whdriver-remove-3v20.sh
inflating: winterhill-main/RPi-3v20/whlaunch-anyhub-3v20.sh
inflating: winterhill-main/RPi-3v20/whlaunch-anywhere-3v20.sh
inflating: winterhill-main/RPi-3v20/whlaunch-fixed-3v20.sh
inflating: winterhill-main/RPi-3v20/whlaunch-local-3v20.sh
inflating: winterhill-main/RPi-3v20/whlaunch-multihub-3v20.sh
inflating: winterhill-main/RPi-3v20/winterhill-anyhub-3v20.sh
inflating: winterhill-main/RPi-3v20/winterhill-anywhere-3v20.sh
inflating: winterhill-main/RPi-3v20/winterhill-fixed-3v20.sh
inflating: winterhill-main/RPi-3v20/winterhill-local-3v20.sh
inflating: winterhill-main/RPi-3v20/winterhill-multihub-3v20.sh
creating: winterhill-main/configs/
inflating: winterhill-main/configs/Check_for_Update
inflating: winterhill-main/configs/Kill_WH
inflating: winterhill-main/configs/PIC_Prog
inflating: winterhill-main/configs/Show_IP
inflating: winterhill-main/configs/Shutdown
inflating: winterhill-main/configs/WH_Anyhub
inflating: winterhill-main/configs/WH_Anywhere
inflating: winterhill-main/configs/WH_Fixed
inflating: winterhill-main/configs/WH_Local
inflating: winterhill-main/configs/WH_Multihub
inflating: winterhill-main/configs/WH_Title.jpg
inflating: winterhill-main/configs/startup.desktop
extracting: winterhill-main/configs/stop.png
inflating: winterhill-main/install_winterhill.sh
extracting: winterhill-main/installed_version.txt
extracting: winterhill-main/latest_version.txt
inflating: winterhill-main/startup.sh
inflating: winterhill-main/update.sh
creating: winterhill-main/utils/
inflating: winterhill-main/utils/check_for_update.sh
extracting: winterhill-main/utils/show_IPV4.sh
extracting: winterhill-main/utils/shutdown.sh
inflating: winterhill-main/version_history.txt
creating: winterhill-main/whsource-3v20/
creating: winterhill-main/whsource-3v20/whdriver-3v20/
inflating: winterhill-main/whsource-3v20/whdriver-3v20/Makefile
inflating: winterhill-main/whsource-3v20/whdriver-3v20/whdriver-3v20.c
creating: winterhill-main/whsource-3v20/whmain-3v20/
inflating: winterhill-main/whsource-3v20/whmain-3v20/LICENSE
inflating: winterhill-main/whsource-3v20/whmain-3v20/Makefile
inflating: winterhill-main/whsource-3v20/whmain-3v20/errors.h
inflating: winterhill-main/whsource-3v20/whmain-3v20/globals.h
inflating: winterhill-main/whsource-3v20/whmain-3v20/main.c
inflating: winterhill-main/whsource-3v20/whmain-3v20/main.h
inflating: winterhill-main/whsource-3v20/whmain-3v20/nim.c
inflating: winterhill-main/whsource-3v20/whmain-3v20/nim.h
inflating: winterhill-main/whsource-3v20/whmain-3v20/rpi2c.c
inflating: winterhill-main/whsource-3v20/whmain-3v20/rpi2c.h
inflating: winterhill-main/whsource-3v20/whmain-3v20/stv0910.c
inflating: winterhill-main/whsource-3v20/whmain-3v20/stv0910.h
inflating: winterhill-main/whsource-3v20/whmain-3v20/stv0910_regs.h
inflating: winterhill-main/whsource-3v20/whmain-3v20/stv0910_regs_init.h
inflating: winterhill-main/whsource-3v20/whmain-3v20/stv0910_utils.c
inflating: winterhill-main/whsource-3v20/whmain-3v20/stv0910_utils.h
inflating: winterhill-main/whsource-3v20/whmain-3v20/stv6120.c
inflating: winterhill-main/whsource-3v20/whmain-3v20/stv6120.h
inflating: winterhill-main/whsource-3v20/whmain-3v20/stv6120_regs.h
inflating: winterhill-main/whsource-3v20/whmain-3v20/stv6120_utils.c
inflating: winterhill-main/whsource-3v20/whmain-3v20/stv6120_utils.h
inflating: winterhill-main/whsource-3v20/whmain-3v20/stvvglna.c
inflating: winterhill-main/whsource-3v20/whmain-3v20/stvvglna.h
inflating: winterhill-main/whsource-3v20/whmain-3v20/stvvglna_regs.h
inflating: winterhill-main/whsource-3v20/whmain-3v20/stvvglna_utils.c
inflating: winterhill-main/whsource-3v20/whmain-3v20/stvvglna_utils.h
creating: winterhill-main/whsource-3v20/whmain-3v20/web/
creating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/404.html
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/index.html
creating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/
extracting: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/404.html
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/click.css
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/click.html
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/constellation.js
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/index.css
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/index.html
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/index.js
creating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/
creating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/
creating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/css/
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/css/bootstrap-grid.css
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/css/bootstrap-grid.css.map
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/css/bootstrap-grid.min.css
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/css/bootstrap-grid.min.css.map
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/css/bootstrap-reboot.css
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/css/bootstrap-reboot.css.map
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/css/bootstrap-reboot.min.css
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/css/bootstrap-reboot.min.css.map
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/css/bootstrap.css
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/css/bootstrap.css.map
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/css/bootstrap.min.css
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/css/bootstrap.min.css.map
creating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/js/
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/js/bootstrap.bundle.js
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/js/bootstrap.bundle.js.map
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/js/bootstrap.bundle.min.js
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/js/bootstrap.bundle.min.js.map
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/js/bootstrap.js
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/js/bootstrap.js.map
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/js/bootstrap.min.js
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.5.2/js/bootstrap.min.js.map
creating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/
creating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/css/
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/css/bootstrap-grid.css
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/css/bootstrap-grid.css.map
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/css/bootstrap-grid.min.css
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/css/bootstrap-grid.min.css.map
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/css/bootstrap-reboot.css
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/css/bootstrap-reboot.css.map
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/css/bootstrap-reboot.min.css
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/css/bootstrap-reboot.min.css.map
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/css/bootstrap.css
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/css/bootstrap.css.map
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/css/bootstrap.min.css
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/css/bootstrap.min.css.map
creating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/js/
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/js/bootstrap.bundle.js
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/js/bootstrap.bundle.js.map
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/js/bootstrap.bundle.min.js
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/js/bootstrap.bundle.min.js.map
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/js/bootstrap.js
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/js/bootstrap.js.map
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/js/bootstrap.min.js
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/bootstrap-4.6.1/js/bootstrap.min.js.map
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/jquery-3.6.0.min.js
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/jquery-3.6.0.min.map
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/socket.io-3.1.1.min.js
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/strWebsocket.js
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/lib/u16Websocket.js
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/htdocs/old/longmynd.js
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/json.c
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/json.h
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/web.c
inflating: winterhill-main/whsource-3v20/whmain-3v20/web/web.h
creating: winterhill-main/whsource-3v20/whpicprog-3v20/
inflating: winterhill-main/whsource-3v20/whpicprog-3v20/make.sh
inflating: winterhill-main/whsource-3v20/whpicprog-3v20/whpic-3v20.hex
inflating: winterhill-main/whsource-3v20/whpicprog-3v20/whpicprog-3v20.c
inflating: winterhill-main/whstop-3v20.sh
inflating: winterhill-main/winterhill-notes-3v20a.txt
inflating: winterhill-main/winterhill.ini
---- Building spi driver for install -----
make -C /lib/modules/5.10.103-v7l+/build/ M=/home/pi/winterhill/whsource-3v20/whdriver-3v20 modules
make[1]: *** /lib/modules/5.10.103-v7l+/build/: No such file or directory. Stop.
make: *** [Makefile:4: all] Error 2
- Failed to build the WinterHill Driver --
pi@raspberrypi:~ $
pi@raspberrypi:~ $ -------------------------------------------------------
Suggested packages:
Get:2 h-bash: -------------------------------------------------------: command not found
pi@raspberrypi:~ $ ----- Installing development version of WinterHill-----
--bash: -----: command not found
---- Download & Install Dependencpi@raspberrypi:~ $ -------------------------------------------------------
pi@raspberrypi:~ $ --------------------------------------------------------
-bash: --------------------------------------------------------: command not found
pi@raspberrypi:~ $ ----- Disabling the raspberry ssh password warning -----
pi@raspberrypi:~ $
-bash: ------------------------------------: command not found
pi@raspberrypi:~ $ ---- Loading required packages -----
-bash: ----: command not found
pi@raspberrypi:~ $
pi@raspberrypi:~ $ Reading package lists... Done
-bash: Reading: command not found
pi@raspberrypi:~ $ Building dependency tree
-bash: Building: command not found
pi@raspberrypi:~ $ Reading state information... Done
pi@raspberrypi:~ $ The following additional packages will be installed:
-bash: The: command not found
pi@raspberrypi:~ $ cmake-data librhash0 libutempter0 libuv1 libxdo3 xbitmaps
-bash: cmake-data: command not found
pi@raspberrypi:~ $ Suggested packages:
-bash: Suggested: command not found
pi@raspberrypi:~ $ cmake-doc ninja-build xfonts-cyrillic
-bash: cmake-doc: command not found
pi@raspberrypi:~ $ The following NEW packages will be installed:
pi@raspberrypi:~ $ cmake cmake-data librhash0 libutempter0 libuv1 libxdo3
-bash: cmake: command not found
pi@raspberrypi:~ $ raspberrypi-kernel-headers xbitmaps xdotool xterm
-bash: raspberrypi-kernel-headers: command not found
pi@raspberrypi:~ $ 0 upgraded, 10 newly installed, 0 to remove and 0 not upgraded.
-bash: 0: command not found
pi@raspberrypi:~ $ Need to get 32.9 MB of archives.
-bash: Need: command not found
pi@raspberrypi:~ $ After this operation, 205 MB of additional disk space will be used.
-bash: After: command not found
pi@raspberrypi:~ $ Get:1 http://archive.raspberrypi.org/debian buster/main armhf cmake-data all 3.16.3-3~bpo10+1 [1,628 kB]
-bash: Get:1: command not found
pi@raspberrypi:~ $ Get:2 http://archive.raspberrypi.org/debian buster/main armhf cmake armhf 3.16.3-3~bpo10+1 [2,500 kB]
-bash: Get:2: command not found
pi@raspberrypi:~ $ Err:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf librhash0 armhf 1.3.8-1
-bash: Err:3: command not found
pi@raspberrypi:~ $ 404 Not Found [IP: 93.93.128.193 80]
-bash: 404: command not found
pi@raspberrypi:~ $ Get:4 http://archive.raspberrypi.org/debian buster/main armhf raspberrypi-kernel-headers armhf 1:1.20220308~buster-1 [27.7 MB]
-bash: Get:4: command not found
pi@raspberrypi:~ $ Err:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf libuv1 armhf 1.24.1-1+deb10u1
-bash: Err:5: command not found
pi@raspberrypi:~ $ Err:6 http://raspbian.raspberrypi.org/raspbian buster/main armhf libutempter0 armhf 1.1.6-3
-bash: Err:6: command not found
pi@raspberrypi:~ $ Get:7 http://mirror.netzwerge.de/raspbian/raspbian buster/main armhf libxdo3 armhf 1:3.20160805.1-4 [30.2 kB]
-bash: Get:7: command not found
pi@raspberrypi:~ $ Err:8 http://raspbian.raspberrypi.org/raspbian buster/main armhf xbitmaps all 1.1.1-2
-bash: Err:8: command not found
pi@raspberrypi:~ $ Get:9 http://mirror.netzwerge.de/raspbian/raspbian buster/main armhf xdotool armhf 1:3.20160805.1-4 [50.6 kB]
-bash: Get:9: command not found
pi@raspberrypi:~ $ Err:10 http://raspbian.raspberrypi.org/raspbian buster/main armhf xterm armhf 344-1+deb10u2
-bash: Err:10: command not found
pi@raspberrypi:~ $ Fetched 31.9 MB in 6s (5,689 kB/s)
-bash: syntax error near unexpected token `('
pi@raspberrypi:~ $ E: Failed to fetch http://raspbian.raspberrypi.org/raspbia ... _armhf.deb 404 Not Found [IP: 93.93.128.193 80]
-bash: E:: command not found
pi@raspberrypi:~ $ E: Failed to fetch http://raspbian.raspberrypi.org/raspbia ... -2_all.deb 404 Not Found [IP: 93.93.128.193 80]
pi@raspberrypi:~ $ E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
pi@raspberrypi:~ $ --------------------------------------------------------------
-bash: --------------------------------------------------------------: command not found
pi@raspberrypi:~ $ ---- Put the Desktop Toolbar at the bottom of the screen -----
pi@raspberrypi:~ $
lpi@raspberrypi:~ $ sed: can't read panel: No such file or directory
g> --------------------------------------
f> ----------------------------------------------
i> ------------------------------------------------------------
o> --2026-01-02 13:38:42-- https://github.com/tomvdb/winterhill/archive/main.zp
e> main.zip [ <=> ] 1.78M 7.02MB/s in 0.3s
i> Archive: main.zip
> pi@raspberrypi:~ $
Re: Winterhill ZR6TG install not working
Post by g0mjw » Fri Jan 02, 2026 3:00 pm
That's possibly the same issue with the recent updates to the raspberry pi archives moving older OS packages to a different location. If it is that, either you will already know how to fix that yourself, or Tom will need to.
Unfortunately the PI foundation make changes that break things on a regular basis and unless the software you want to install is actively maintained, you can not expect older software to continue to install successfully.
DL5BCA
Post by DL5BCA » Fri Jan 02, 2026 3:13 pm
Thanks Mike.
I've contacted Tom. He might already be working on a solution.
It would be a shame if it couldn't be reinstalled.
Thanks for the tip.
73 and a happy new year
